sand point replacement
Discussion in 'Pumps and Tanks Well Forum & Blog' started by farther north, Mar 16, 2009.
  1. farther north
    farther north New Member
    Mar 16, 2009
    I plan on pulling my sand point and replacing it.
    Can I drive the sand point into the same hole, where the old one was removed; or do I have to move it over a little bit and start a new hole?
  2. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    Why do you need or want to pull it?
    If it's very deep it may be hard to get out. The sand acts like a vise.
    If it's pvc, you take a big chance on pulling the screen apart.
    If it's all steel, it may come out, or at least you have a better chance on getting it out.
    Travis
  4. farther north
    Mar 16, 2009
    I'm having trouble getting water.
    I live about 50 feet from the lake (flowage). They drained the flowage down to nothing; and I have a big muddy mess, which use to be a lake.
    Either I have a plugged up screen or the water table is to low.
    The pipe 1 1/2" is steel. What everyone around here says is the point is about 15 to 20 feet deep.
    Before I start this project. I want to know what I can and can't do.
    I don't know if I should pound it down more or pull it.
    But my best guess is that the point is about 25 years old.
    So, I'm thinking it is plugged.
    Thanks for your help!
  5. Waterwelldude
    Feb 11, 2009
    Texas
    If it is plugged, you may be able to clean it out.
    That is assuming, the water has not gone down to far for your well.
    You can use compressed air to blow the well out.
    Run a 1/2" pipe down to the bottom of the well, and use a compressor to blow the water out. Do this 10 to 20 times. You may be able to see if the water flow improves or not. If the water has dropped lower than you well point, it may not do any good.
    There is a product called (new-well). It is used to rehabilitate old wells. Sometimes it works, sometimes it doesn't. You would need to talk to a well supply house to it's proper use. It is a type of acid, and caution should be used.
    As for going deeper. The sand that your well is set in, may not go any deeper than it is now.
    You should check the depth of your well, and compare it to other close by.
    If others are 15' to 25', and yours is 25'. Chances are not in your favor that going deeper will do any good at all.
    Just some thoughts I had.
    Hope it help some.
    Travis
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I like Nu-Well, but it has to be followed with lots of water to dissolve and activate the tablets for hours after putting them in the well.
    Pounding down on the well a foot or two might make it start producing again, but may also be somewhat temporary.
    Pulling it is going to be a challenge, but is possible. I have done a ton of them when I was young and stupid.
    bob...
  7. farther north
    Mar 16, 2009
    I heard of Nu-well but can not locate any in Wisconson.
    What does this do?
    I having a hard time navigating and locating things on this web site.
    So, if I don't find you again.
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Do a search here for Nu-Well. I know I have put several links to places that sell them here.
    bob...
  9. farther north
    Mar 16, 2009
    sand point
    Thanks to you all.
    You all been a help!
    But no one answered my first question.
    If I pull the sand point; can I put the new one down the same, whole that the old one was in?
  10. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Going back down the same hole is totally not recommended. The water bearing material on the outside of the well screen can be just as plugged up as the well screen. I would place a new well a minimum of 5' away from the old one. Before installing a new well, you should check with your local board of health concerning regulations.
    sammy
    www.tylerwellandpump.com
  11. speedbump
    Jul 15, 2005
    Riverview, Fl.
    We used to do it all the time.
    Sammy is right, the junk that built up in the sand around the old screen is still there in the same place the old screen was. You will still see a large difference in the wells production though. You could also drive it a few feet further to get into some fresh sand, if it will go deeper without going out of the vein.
    bob...
  12. farther north
    Mar 16, 2009
    sand point
    Well, thank you all for the help.
    When the weather warms up I'm going to try some of your suggestions.
    First try to blow the screen clean.
    Then try driving it down more.
    Then I guess I will have to replace it.
    To put it 5 feet away from where it is now may not work. It would put the pipe out in the open and may cause freezing in the winter.
    It has to stick out of the ground 1 foot.
    That would put the pipe 7 feet from the house and in the open.
Similar Threads: sand point
Pumps and Tanks Well Forum & Blog Shallow Well Sand Point Losing Prime Overnight? May 8, 2016
Pumps and Tanks Well Forum & Blog Sand Point Well Low Yield Nov 12, 2015
Pumps and Tanks Well Forum & Blog DIY Shallow Well with 1-1/4" Sandpoint Installation Nov 10, 2015
Pumps and Tanks Well Forum & Blog SAND POINT SHALLOW WELL ?'s Nov 5, 2015
Pumps and Tanks Well Forum & Blog Shallow well (sand point?) not pumping any water Oct 16, 2015
