I have had a sandpoint well in northern wisconsin for 30 years. Every couple of years I need to pull and replace the point because it becomes plugged. When I replace the point I get about 5 GPM but after a couple of years I need to measure in minutes per gallon (really). Also, if I run too much water (like several toilet flushes and several consecutive showers) the well goes dry for 12 hours or so.
The 1.25" X 36" point is down 13 feet at the bottom and the static water level is around 7 feet. To try and get away from the tri-anual replacement ritual and the dry spells, I decided to drive a 2"X36" with larger screen size and I went to 19'. As it turns out there is no water at 19'. I fill the pipe and the next day it's still nearly full. So it appears that I overshot the vein.
Here is my question. I have it in my head that I need to go deeper to find a more reliable vein. How likely is it that there is a second deeper vein? Or am I better off pulling back up and testing every so often to find an optimal position in the vein that I know is there? My concern with the latter is that the well will continue to run dry on occasion and I also worry about contaminants this close to the surface.
Any advice would be greatly appreciated.
Bob
Bob
