Salty taste to water
Discussion in 'Water Softener Forum, Questions and Answers' started by TerrySB, Nov 27, 2012.
  1. TerrySB
    TerrySB New Member
    Nov 27, 2012
    Santa Fe, TX
    I have a Kinetico water softener, Model #60, since 1988. I have had no problems since I bought it. In the past weeks, the water has been tasting salty, too salty to drink and use. The drain line is clean. There is a mention that the head on the resin tanks could not be working correctly.
    Can someone tell me what they think the problem can be? Can the head be changed out on the resin tanks and if so, what would the exact name of the part and part number be?
  2. Gary Slusser
    Have you checked the raw water for the same taste? If not you should put the softener in by pass and run water to all sink faucets for a few minutes to flush the lines and then at the kitchen sink, let it run for a few minutes and taste it. Or if you have your own well and can get water from the pressure tank to taste, do that.
    If no salty taste then the most common cause of salty water is incomplete rinse, which since the drain line is not blocked or kinked should be eliminated as a potential cause, could mean there is too much salt being used to be successfully rinsed out in the length of time the rinse runs for. So is the water level in the salt tank the same as it used to be before the problem started or higher than normal? Maybe a drain line flow control button is partially blocked. If I'm right that would be inside the control valve on a Kinetico. Probably where the drain line connects to the valve. Let us know what you find.
  4. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    I have a manual and exploded view of the internal part. Just send me an e-mail and I'll send them to you.
Similar Threads: Salty taste
Water Softener Forum, Questions and Answers Salty taste in fresh water lines Apr 1, 2016
Water Softener Forum, Questions and Answers Kinetico Softener with salty taste during regen. Help!!! Aug 21, 2015
Water Softener Forum, Questions and Answers New install, 7000SXT, salty foamy water Dec 31, 2015
Water Softener Forum, Questions and Answers Salty hard water after regeneration Aug 15, 2015
Water Softener Forum, Questions and Answers Darn water is too salty Kinetico Signature Series Nov 10, 2014
