salt in water due to softner
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by polocash, Mar 28, 2005.
  1. polocash
    polocash New Member
    Mar 27, 2005
    Does using a water softner with salt put salt into the drinking water?
    I have been told yes and no by plumbers.
  2. hj
    If you use salt in the brine tank then it introduces sodium into the water, not salt. And since sodium is the thing many people are trying to avoid, using potassium as a regeneration medium, or installing a reverse osmosis system for drinking water can minimize that problem.
  4. Gary Slusser
    Sodium is added at the rate of 7.875 mg/liter per grain of 'hardness' (all exchanged ions including iron, manganese, lead, copper etc.). And usually only folks on low or sodium restricted diets have a concern but then they know how to limit their sodium intake. If you check how much sodium will be added by your water, and then compare that amount to food and beverage labels, you'll see you already injest much more sodium than will be added by a softener if you drink that all but quart of water every once in awhile.
    If you use potassium chloride instead, and you are dosing your softener for the best 'salt' efficiency, you must use about 20% more than if you were using sodium chloride.
    Quality Water Associates
Similar Threads: salt water
Plumbing Forum, Professional & DIY Advice salt on water heater Oct 20, 2012
Plumbing Forum, Professional & DIY Advice Will Inland Salt Water Corrode Fittings? Jan 23, 2009
Plumbing Forum, Professional & DIY Advice Water in the bottom of water softner salt tank. Mar 16, 2008
Plumbing Forum, Professional & DIY Advice Salty Water Softener Oct 30, 2007
Plumbing Forum, Professional & DIY Advice faucet recommendation for salt water Jun 26, 2007
