Safe Pressure Treated Lumber...
Discussion in 'Remodel Forum & Blog' started by I26, Apr 19, 2007.
  1. I26
    I26 Member
    Jul 2, 2006
    Reading, Pennsylvania
    I havebeen learning of the really harmful effects of Pressure treated wood containing CCA, (aka. arsenic). It is said to last over 20 years and absorbs easily into a childs skin. So where might one buy wood that is safe? I heard of some called ACQ pressure treated pine but am not sure where to find it. Anyone up on this topic that can maybe help with some insight?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    I believe all retail lumber distributors no longer stock CCA lumber. They have switched to the safer types. The lumber will be well labeled, and even the newer types I imagine one should limit exposure by wearing gloves and dust mask during construction.
  4. bonawizer
    bonawizer New Member
    Apr 20, 2007
    decks,sheds,interior repair/remodel
    central pa
    check this
    Check out this site; www.sutherlands.com
    It specifies what kind of fasteners you need to use, and has links to more info.
    Marc
  5. Cookie
    Cookie .
    Oct 7, 2005
    I did an article on it once, mostly the concern was the wood being used in the playground equipment. Kids breathing the effects of it, running their hands over it, putting their mouths on it. Also, alot of the mulch that is used, is being restricted on playground use as well. Tests have shown, that some mulch, carry bacteria, which can cause illness when the kids' barefeet goes in it, hands with small cuts play it in, and again, breathing it. Along with as well, some playgrounds were used prior for chemical dumping grounds.
Similar Threads: Safe Pressure
Remodel Forum & Blog Tornado Safe Room Jan 11, 2017
Remodel Forum & Blog Safe to cut out stud from this wall? May 26, 2012
Remodel Forum & Blog Brasscraft Gas Flow-safe valve Jul 12, 2010
Remodel Forum & Blog Retro fitting a victorian tub with safey rails Nov 2, 2008
Remodel Forum & Blog Water pressure woes Mar 14, 2017
