Saddle Valve Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by michaedt, Jan 19, 2006.
  1. michaedt
    michaedt New Member
    Dec 2, 2005
    I recently replaced all of my supply lines, but I still need to connect my whole-house humidifier to the water line. It looks like a 1/4" line (like my refrigerator water line). Previously, it was connected to a 3/4" cold water supply via a saddle valve.
    Is this the best way? Can I turn off a saddle valve once it’s been tapped? I want to be able to change the line when it clogs without having to shut off my entire water supply. I considered putting a 3/4 to 1/2 T, running 1/2 toward the furnace with a shut-off along the way, and then finding a compression adapter (if one exists) to go from 1/2 to 1/4. Perhaps this is overkill. Any opinions?
    Thanks,
    Danny
  2. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    Your plan is the best option. Saddle valves are not the most relilable method. It will not take too long to cut in a tee, add a shut off valve and a compression fitting to get you to 1/4".
  4. michaedt
    michaedt New Member
    Dec 2, 2005
    Thank you
    Thank you Finnegan! I'll give it a try.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Saddle valves usually end up causing problems sooner or later.
  6. Lancaster
    Lancaster New Member
    Nov 7, 2005
    Get an icemaker angle stop,it already has a 1/4" compression outlet.Then use the polymer-braided (looks like stainless) tubing icemaker connector.
  7. michaedt
    michaedt New Member
    Dec 2, 2005
    perfect
    Perfect! Thank you!
  8. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    Just an FYI we just had a new furnace put in and the current preferred method is to use hot water into the humidifier. At least that is the case with my April air unit that has no standing water. It just runs when needed. Hot evaporates better is the reason.
Similar Threads: Saddle Valve
Plumbing Forum, Professional & DIY Advice Question adding water line to sink No saddle valve Jan 29, 2014
Plumbing Forum, Professional & DIY Advice Saddle Valve too tight Jan 4, 2013
Plumbing Forum, Professional & DIY Advice Saddle Valve leaking Feb 15, 2012
Plumbing Forum, Professional & DIY Advice saddle valve on black pipe May 12, 2008
Plumbing Forum, Professional & DIY Advice Saddle Valve into flex water supply line? Mar 30, 2007
