Saddle Valve into flex water supply line?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kine97, Mar 30, 2007.
  1. kine97
    kine97 New Member
    Mar 30, 2007
    Indiana
    We are going to change out our Kitchen sink & faucet. We want to use the flexible Faucet Supply Lines, but don't know if we can tap into the cold water flexible faucet supply line with a Saddle Valve to run water to the Ice Maker. Does any one know if it is possible, or do we have to have some type of rigid water supply line running to the cold water side?
    We're also wanting to run an under-the-sink filter to a separate filtered faucet. We will use a shutoff valve that has two 3/8'' comp. for the 2 different faucets on the cold water side.
    I hope all this makes sense.
    Thanks in advance for any advice.
    Theresa
  2. hj
    supply
    Saddle valves are NEVER a good choice and will definitely not work on anything other than straight hard copper. Use a "3 way" valve which has two outlets, either both 3/8" or one 3/8" and lne 1/4", (this is more common and useful for water filters, etc.).
    [​IMG]
  4. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    If you don't want to change the valve, buy or assemble a Tee/manifold that will screw on to the existing valve and give separate connections for the two lines.
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    You can use a 3/8" X 1/4" compression tee on the faucet supply...
    Run from the valve to the T and from the T to the faucet 3/8"...
    From the branch serving the appliance (1/4"), run a piece of 1/4" copper and then a 1/4" shutoff valve (compression...) then run to your appliance...
  6. hj
    tee
    If you are going to install a tee, use a BrassCraft "add a tee" that fastens to the valve and then the risers connect to it.
Similar Threads: Saddle Valve
Plumbing Forum, Professional & DIY Advice Question adding water line to sink No saddle valve Jan 29, 2014
Plumbing Forum, Professional & DIY Advice Saddle Valve too tight Jan 4, 2013
Plumbing Forum, Professional & DIY Advice Saddle Valve leaking Feb 15, 2012
Plumbing Forum, Professional & DIY Advice saddle valve on black pipe May 12, 2008
Plumbing Forum, Professional & DIY Advice My saddle valve is dripping. Dec 12, 2006
