Rusty Tub
Discussion in 'Shower & Bathtub Forum & Blog' started by Toy, Oct 28, 2013.
  1. Toy
    Toy New Member
    Oct 28, 2013
    Michigan
    Please explain why my tub keeps rusting like this. I've applied CLR (Calcium Lime & Rust) 3 times and it keeps going back to its usual stage. What can I do to save me some money or should I just call a professional?
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Is that the only place with such rust? The inside of your toilet tank is not rusty?
    Is the finish all worn off there? If not , try putting a plastic container over that spot, and see if the rust is dripping down from the shower head.
  4. Toy
    Toy New Member
    Oct 28, 2013
    Michigan
    It's the only place. I don't think it's the shower head. And yes the finish is worn.
  5. Reach4
    Sep 25, 2013
    Search for tub refinishing OR reglaze in your favorite search engine. I don't have personal experience with that, but you should find a lot of references in a search engine.
  6. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    I would look into replacing the tub.
    You can re-glaze it for about $300, and it would last 2-5 years.
    You can clean it weekly - for the price of a cleaner.
    Or you can install a new tub: an enamel steel tub (about $225 + labor) is good for 10-20 years. Cast iron (Kohler is around $400 + labor) is good for longer. YMMV.
  7. Terry
    Aug 17, 2004
    Are you sure that's not rust from the water?
    Often we get a bit of rust in the tub from the galvanized pipes.
    Even a home run in copper may have galvanized pipe for the tub spout.
  8. Toy
    Toy New Member
    Oct 28, 2013
    Michigan
    Just that little spot will cost me $300?. Wow!! I'm just a renter. I showed the landlord, he humped his shoulders and said it could be iron in the water that's causing it. Which means he didn't care I guess. I probley won't be replacing the tub nor reglazing for that price. But thanks so much!
  9. Toy
    Toy New Member
    Oct 28, 2013
    Michigan
    Yea he stated that it could be the water. But he said the water could have iron in it.
  10. Reach4
    Sep 25, 2013
    Try putting a plastic container over that spot, and see if the rust is dripping down from above.
  11. Toy
    Toy New Member
    Oct 28, 2013
    Michigan
    Ok going to try that now. Keep you posted!
  12. dj2
    Aug 13, 2013
    California
    Re-glazers do entire tubs.
    About the landlord: the least he could offer you was a whole house filter ($20 + $6 for a filter at Lowes). Ask him about it.
  13. hj
    IT looks like an enameled steel tub and if so the finish is gone in that area and the steel is rusting through it. I would never invest a penny into refinishing a steel tub, nor would I install one, unless the customer bought it so I did not have to guarantee its performance or durability.
  14. Toy
    Toy New Member
    Oct 28, 2013
    Michigan
    Its not leaking.
  15. Reach4
    Sep 25, 2013
    I guess you could try car wax on the spot after you clean the rust off, and dry the spot after each tub use. Reapply wax as needed.
    Read about https://www.rustoleum.com/CBGProduct.asp?pid=116
    I have no personal knowledge of it. I don't know how it would be as a touch up vs covering the whole tub. Consult with the landlord beforehand.
  16. IM3rcy
    IM3rcy New Member
    Jul 14, 2016
    Poland
    It depends on how much rusted is your bathtub. If refreshing it with home remedies will be too hard, and if you live in the Chicago area, I know one reliable company . http://www.aprefinishing.com/. For 3 years my bathtub is in good condition.
  17. jadnashua
    If you're a renter, and have alerted the landlord, unless he is willing to install a new tub, I think you'll just have to live with it. Touching anything like that could get really messy.
  18. hj
    quote; Just that little spot will cost me $300?.
    The CANNOT do "just that little spot". There is no way they could match the "old" color after all those years so would have to redo the entire tub, and I do not think they could do that for just $300.00. A tub "reliner" maybe.
Similar Threads: Rusty
Shower & Bathtub Forum & Blog Advice on what to do with rusty drain in Shower Stall Dec 22, 2015
Shower & Bathtub Forum & Blog Rusty Drain, New Condo, Marble Floor, Unknown Material - help please Dec 14, 2015
Shower & Bathtub Forum & Blog Rusty water from new handshower installation Oct 17, 2008
Shower & Bathtub Forum & Blog Bathub leak by rusty drain area Sep 9, 2007
Shower & Bathtub Forum & Blog Covering a rusty tub drain Mar 2, 2007
