Rusty Brown water?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by willbill44, Dec 2, 2007.
  1. willbill44
    willbill44 New Member
    Dec 2, 2007
    Manage business
    North Carolina
    Recently we replaced a tub/shower valve in my thirty year old home.
    I broke one of the connections trying to rebuild the control valve. I called a licensed plumber to minimize the down time with the water turned off.
    The plumber had a inexpensive single handle set on his truck.
    He used pex fittings to tie into the homes' copper pipes.
    The whole thing works fine, However, in a short time we started getting rusty, brown water when the faucet is first turned on. After the first few seconds the water is clear as ever. Most important fact....no other faucet produces this type of water.
    Is it the fittings?
    Would appreciate if this problem has occurred and what is necessary to correct.
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    I don't know what all he replaced, but if he used a galvanized tub spout fitting or any galvanized anywhere else, then that the problem. It needs to be replaced with copper or cpvc or anything else that won't produce rust.
    Mike
  4. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Whenever you disturb old galvanized pipe, you break loose a lot of rust and buildup. There may be a chunk of it in the pipe that's disintegrating slowly. Either it will eventually clear up so it's no longer noticeable, or it will plug something.
  5. westcoastplumber
    westcoastplumber Plumbing Contractor
    Nov 30, 2007
    c-36 plumbing contractor
    los angeles
    Sounds like you may have galv to the tub spout or shower riser.
    You may have disturbed a buildup in your water meter or shut off valve on the main water supply.
    Anyway you can take pictures of the new install? Did you notice this brown water right away? or did it come later?
    You said they tied the pex to the copper, so this makes me assume the rust is coming from the water heater, isolation valve or another source.
    what brand of valve did he install??
  6. willbill44
    Dec 2, 2007
    Manage business
    North Carolina
    Additional info on tub valve change out and brown water.
    My house has copper pipes only. The plummer installed a Delta tub/shower valve. He used pex (white plastic pipe) to tie in to the house piping and transition to the the valve. The fittings may have been brass. Its behind the wall so I can not take a picture at this time. We had the house on the market at the time so we were in a rush to get everything repaired quickly. I have notified the plummer of this problem but he has not responded. There is no galvanized pipe used.
    No other locations have this brown stained water.
    Will:
  7. westcoastplumber
    Nov 30, 2007
    los angeles
    Dealta is an all brass valve and I have never had any complaints about rust coming from the valve.
    If the whole house is copper and there is pex for the shower valve install, and the shower head and tub risers are pex or copper, and the tub spout nipple is brass or copper, then you would not be gettting rust from this fixture.
    Is it the first fixture closest to the water heater? Maybe rusty nipples coming out of the water heater and you only noticed it cause you had the shower valve installed and it caught your eye??
Similar Threads: Rusty Brown
Plumbing Forum, Professional & DIY Advice How can I get rid of brown/rusty water?? Dec 2, 2006
Plumbing Forum, Professional & DIY Advice Tricks to clear rusty floor drain trap Dec 4, 2015
Plumbing Forum, Professional & DIY Advice A rusty burst of water everytime... Feb 1, 2014
Plumbing Forum, Professional & DIY Advice Rusty Water in Bathroom Tub Only Mar 10, 2011
Plumbing Forum, Professional & DIY Advice removing rusty drain from antique sink Oct 30, 2009
