Rust particles in hot water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ac38, Feb 5, 2008.
  1. ac38
    ac38 New Member
    Jun 22, 2007
    I have recently noticed tiny rust particles in a cup after running hot water from my sink. The water is clear. I have the original boiler which is 35 yrs. old which was put in when the house was built and still running ok. Its a combination boiler for hot water gas heated baseboard heat and hot water for sink, shower, etc. I have copper pipes. There has been no water pipe repair work being done outside the home by the town and we use town water.
    I would appreciate everyones comments as to where the rust might be coming from.
    Could it be that the old boiler is discharging the rust particles and needs replacement?
    Thank you.
  2. jadnashua
    Sounds like you may be right...could be the heat exchanger in the boiler is going. See what the pros have to say. Sure there's no galvanized piping anywhere? Do you see this if you run hot from other sinks or say the tub? If you get it everywhere, it's in the supply. If it is only on one sink, it's probably not the boiler.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't have any boiler experience, but if you have rust appearing in your water, it has to be coming from iron or steel and it sounds like the only critter that has iron or steel is the boiler. Can't even guess if it needs immediate replacement or what else might be done. Hang in here, there are people that know about boilers that will probably chime in.
Similar Threads: Rust particles
Plumbing Forum, Professional & DIY Advice rust particles in bathroom sink drain Jan 23, 2017
Plumbing Forum, Professional & DIY Advice inline, course filtering of rust particles in supply line May 12, 2015
Plumbing Forum, Professional & DIY Advice Rust particles coming out. Apr 29, 2008
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Water heater rust? Conflicting advice... Sep 21, 2016
