Rust colored water
Discussion in 'Water Heater Forum, Tanks' started by mriceman2004, Apr 19, 2009.
  1. mriceman2004
    mriceman2004 New Member
    Apr 19, 2009
    I have a Bradford white 75 gallon high efficiency hot water heater '97. Rusty water started about 2 months ago. Flushed it twice, still rusty. Heats water great, no leaks.... Is this fixable????
  2. jadnashua
    It could be the tank, it could be steel fittings attached to the output or inlet. If it is the tank, you're on borrowed time. You might try replacing the anode rod, but you probably need to budget for a new one, soon.
    Is the rust at each hot faucet, or only one or two? If you drain some from the tank, is it rusty there?
  4. mriceman2004
    Apr 19, 2009
    Thanks for the reply...
    The rusty color is at all taps, tub, shower only when hot water is used... Flushed tank twice now and did not notice any improvement. There are no steel connctors, is changing anode a possibility??? And how expensive is a job like that???
  5. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Are you on a well?
  6. mriceman2004
    Apr 19, 2009
    No we are supplied water (cold water is clear)
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Put your pennies aside it's almost time for that new Bradford White whether you like it or not....
    [​IMG]
  8. jadnashua
    One reason steel ships don't rust away to nothing is because they have sacrificial anodes applied around the hull. Removing the old anode, probably totally disintegrated, would slow the rust, but once started, it could be over soon. Unscrewing the old anode is the tough part...they don't cost much. If you don't have enough height to install a standard one, they make them with segments so they can be bent so you have room to install. An impact wrench really helps getting them out, but you may be able to do it with a socket with a long cheater bar. if yo uhave to pay someone to do this, it wouldn't be too cost effective, as there's no guarantee it would have been done in time...there may be too much damage already. If you replace the anode rod periodically, the tank should last longer for not much cost.
Similar Threads: Rust colored
Water Heater Forum, Tanks AO Smith and Red (Rust) Water When Draining Dec 6, 2015
Water Heater Forum, Tanks Crusty cold water inlet Dec 6, 2015
Water Heater Forum, Tanks Rusty water from heater Dec 3, 2015
Water Heater Forum, Tanks Expansion tank Schrader fitting rusted almost shut? Feb 7, 2015
Water Heater Forum, Tanks Rust in water tank Jan 7, 2014
