Rushing Water Noise
Discussion in 'Irrigation / Sprinkler Forum' started by kriegrelic, Jun 18, 2007.
  1. kriegrelic
    kriegrelic New Member
    Jun 18, 2007
    I just recently opened my irrigation system for this year. I noticed a sound of rushing water from the pipe that runs to the outside that wasn't there before. This loud rushing water sound continues until all of the zones have run their course. After the last zone is complete the sound stops. Or, if I turn off the shutoff valve to the irrigation system the sound stops. Could the problem be the pressure vacuum breaker on the outside of the house (Febco). I'm not on city water, but rather a well system. This noise is loud and wakes does wake me up when I run the sprinklers late at night. Is this normal? Doesn't pipe noise usually indicate a pressure problem? Any suggestions?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    You may have a split pipe that is spraying when the system is on. Is this a new sound since last year?
  4. kriegrelic
    Jun 18, 2007
    Rushing Water in Pipe
    I should have clarified that the rushing water noise is in the 1" copper pipe in the basement of my house from the well to the exterior wall. There doesn't appear to be any leaks where this 1" copper line either in the house or when it exits the house and enters the Febco backflow preventer. Is this sound normal? I don't recall it being that loud when the system is operating in years past. I strongly suspect something is amiss in the backflow preventer. Would I be on the right track in assuming this?
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't know if the sound could be coming from the backflow preventer, but a backflow preventer should be tested by a certified technician every spring. In my city, the testing is required by the city. This is not true everywhere, but they should be tested anyway.
Similar Threads: Rushing Water
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Yard hydrant/automatic horse waterer question Sep 5, 2016
Irrigation / Sprinkler Forum Things to buy to do under ground water line? Aug 14, 2016
Irrigation / Sprinkler Forum How would I still have water in sprinkler lines? Mar 3, 2016
Irrigation / Sprinkler Forum Designing a sprinkler system to put water on house during brush fire Jul 22, 2015
