Running Water Sounds In Baseboard Heat
Discussion in 'HVAC Heating & Cooling' started by patmac, Jan 20, 2008.
  1. patmac
    patmac New Member
    Jan 20, 2008
    Hi,
    We have an old ( circa 1972 ) Crown Boiler for hot water and heating.
    About three weeks ago, we started hearing running/rushing water sounds in the baseboard heating pipes when any of the zones turned on. It last about a minute or two, then we hear the regular moans and groans of the baseboards. The rushing water sound is new. This only happens with the heating zones, not the household hot water supply.
    Any ideas would be appreciated.
  2. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    Have you let the air out of (bled) the system and made sure the circuit/boiler has the proper amount of water in it?
  4. patmac
    patmac New Member
    Jan 20, 2008
    Either the bleeder valves on the boiler are all clogged up or I don't know how to work them. Also, how do I know what the proper amount of water is, by the pressure on the indicator? That is only between 8 and 10 PSI if I'm reading it correctly. Thanks
  5. jadnashua
    I'm surprised it works with only 8 pounds...most safety valves require at least 12-13 or more pounds pressure to satisfy the low-pressure safety interlock. You may need to check both the switch and gauge - one or both are off. What temperature do you run the boiler at? Rushing water sounds means air in the system. Rumbling could be steam if things aren't flowing well and the pressure is too low.
  6. alternety
    Apr 2, 2006
    Washington
    Look around the ends of the baseboard units - see if you can find vents on each one. The bleeding has to happen at high points in the plumbing. There should be a water supply line going to the boiler. It probably has a shut off valve and needs to have a backflow preventer. That needs to be turned on and providing water when you do the bleeding.
    Did you recently purchase the house? Has yearly maintenance been done? If no regular maintenance has been done, I would probably get someone in that understands hot water boilers and have it cleaned, flushed, and checked.
    And see if you can find a manual.
  7. patmac
    patmac New Member
    Jan 20, 2008
    Hi,
    I did a search for Crown boilers, could not find the "oldies" section in tech support for manuals. Just from all the helpful input from you guys, I think I'm going to get some professional help on this one. The pressure is real low, the temp goes really high(over 180) in the boiler, plus it's due for an over haul. We will be upgrading it soon due to an addition on the house, so I hope it's not too expensive of a tech call. Any idea of how much to expect? Thanks again for all your time.
  8. patmac
    patmac New Member
    Jan 20, 2008
    Since it was in the teens here, we decided to get some help with this. Turns both auto vents were bad, as well as the auto fill valve. The Tech said we were a couple gallons of water away from cracking the boiler tank. I picked the Tech's brain, and watched everything, he was a good guy. I know exactly how the boiler works now, for the next time. Thanks for all the help here.
Similar Threads: Running Water
HVAC Heating & Cooling Water running out fresh air inlet pipe Jul 26, 2011
HVAC Heating & Cooling AC Fan Not Running, Thinking Capacitor, but.. Yesterday at 1:57 PM
HVAC Heating & Cooling Does running two trunklines address the problem of trunkline duct being too small Nov 19, 2015
HVAC Heating & Cooling Main blower won't stop running Dec 28, 2014
HVAC Heating & Cooling Heat pump fan not running May 27, 2013
