Running Sink Drain Pipe Into Trouble
Discussion in 'Remodel Forum & Blog' started by pauloscar16, Oct 21, 2013.
  1. pauloscar16
    pauloscar16 New Member
    Oct 21, 2013
    GC
    DC
    Before the plumber comes in and at his request,I am starting to plan vents and drains on a multi-floor bathroom remodel, but I have a problem. I can't think! Brain dead.
    Q: In the master bathroom, the sink drain goes does through the wall's bottom plate narrowly missing an 80 year old joist hanger (massive),
    however, after going through the wall's bottom plate it goes directly into the floor joist below (and the sistered 2 x 8 for securing the new floor substrate).
    I can not cut a notch through half that joist for I would jeopardize the joists integrity and break code so what should be done?
    I also have to run 1/2" supplies on either side.
    The drain's hole should be at 31" center for the 62" vanity, that is
    just right of new wall stud and just left of hanger, but there is a floor joist directly below the plate.
    The vanity is custom built gorgeous and I don't want to mess with it.
    Any ideas?
  2. Terry
    Aug 17, 2004
    Most cabinets have a 3.5" kick space below. Does this one?
    We sometimes have to use that space if there is structure we need to miss.
    Also, you can trap arm over up to 42" from the vent if that helps. That includes the distance to the p-trap.
  4. pauloscar16
    Oct 21, 2013
    GC
    DC
    The cabinets are still being built and that could work.
    Thank you very much.
    I believe I am good with the venting.
    O.
  5. hj
    quote; Before the plumber comes in and at his request,I am starting to plan vents and drains on a multi-floor bathroom remodel,
    I would NEVER ask a customer to "plan vents and drains", unless I were incapable of doing it myself, in which case I would NOT be a professional plumber. Therefore, I have to question WHO you hired.
Similar Threads: Running Sink
Remodel Forum & Blog Remodeling bathroom.. Running drain pipes Sep 16, 2010
Remodel Forum & Blog Running DWV through framing in an old house Dec 7, 2008
Remodel Forum & Blog Advice on running waste pipe Oct 17, 2005
Remodel Forum & Blog Running new copper Oct 9, 2005
Remodel Forum & Blog And yet another "add sink in the laundry room" post! Apr 5, 2017
