I looked thru several of the earlier postings on the forum - found some similar ones, but not quite the same. I have a Craftsman 1hp deep well pump and captive air tank. These are both brand new - installed in December. I talked to the previous owner of this house - I think he said the well is 200' deep and the static level is 60'.
We think our problem is that the well itself is running low on water but want to be sure. The pump will run, but only gets up to 20# - keeps running until we unplug the pump. When we plug the pump back in, it will not start again until we run some water. The pressure switch is set at about 12 for on and 38 for off. The past few days, after we unplugged the pump, we could see the pressure dropping on the pressure gauge - got down to zero a couple of times. Although we live a in rainforest in SE Alaska, this has been a very dry winter. So our theory is that we are going to have to wait until we get some good rain and the aquifer fills up.
Is this a good theory or are we missing something? How would we be able to tell if it is the foot valve? Looking at the book that came with the pump, it shows a jet with a check valve inside the well casing. How would we know if that is the problem?
Thanks for your help!
