running drain through studs, according to code?
Discussion in 'Canadian Plumbing Code Questions' started by navid, May 26, 2012.
  1. navid
    navid New Member
    May 26, 2012
    Toronto
    Hi,
    The plumber doing my basement plumbing is running kitchen drain through the studs (drilling them) to the old washroom drain. the length of the running is 27 feet and it has 10 elbow(90 degree) from kitchen to old drain. Is it according to Ontario code?
    thanks
  2. hj
    There is almost NO code that would allow a 27 foot drain line to have TEN elbows in it. And a good plumber would find a way to NOT put that many in, in the first place.
  4. navid
    navid New Member
    May 26, 2012
    Toronto
    here is the plan for the basement. Kitchen drain starts from the pink circle and the existing drain which run from ceiling to basement floor, are the red ones. Thanks for your ideas.
    [​IMG]
  5. hj
    Apparently this is a DIY design, because most professional designers would have revised the plan so the drain did NOT have to run that way. You have at least two problems.
    1. To be "legal" he will have to install an "accessible" cleanout at almost every turn
    2. The sink drain WILL clog up frequently, so you should buy a good drain snake and learn how to use it.
  6. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    i would assume there is no permit involved or you wouldn't be asking if it is to code.
    it is a terrible layout at best, but it would be to code provided it is vented properly, has proper slope and has accessible cleanouts located every 6m and a cleanout on the trap arm or union p-trap
  7. Plumber1979
    Plumber1979 Certified Plumber
    Jul 15, 2012
    Certified Plumber
    Ontario
    i would move the sink closer to the existing drain
Similar Threads: running drain
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions Washing Machine with Utility Sink - 1-1/2" Drain! Dec 6, 2016
Canadian Plumbing Code Questions Want to tie into washing machine drain Mar 7, 2016
Canadian Plumbing Code Questions Dishwasher direct drain to basement and main soil stack Sep 18, 2015
Canadian Plumbing Code Questions Raising fixture drain Dec 17, 2014
