Running circuits along roof?
Discussion in 'Electrical Forum discussion & Blog' started by Nate R, Jun 26, 2008.
  1. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    My main panel is in our back entrance to the house, a little 4X4' area that was added on to the original house. I will be rewiring just about everything.
    The easiest/best route to the 2nd floor (really a 1/2 story) is along the roof of the house. The rafters are only 4". (Really closer to 3 3/4." VERY old wood.) So, I need to maintain 1 1/4" depth from both sides, correct? One one side to keep drywall screws from penetrating, and on the other side to keep stray roofing nails from penetrating.
    I was thinking of running NM cable this way. 4-5 circuits.
    So can I fasten them to the side of the rafter itself smack in the middle of it? Or is this considered unsafe enough that I should consider this part of the run in BX or feed individual wires in conduit?
  2. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    Nothing? Is my question not clear enough, or is there something else I need to add?
    I just need to know if I should protect NM anymore under a roof than I would in a wall?
  4. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    You do not have to drill them. Are you asking to lay the cables on top of the ceiling joist, or nail them along the roof?
  5. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    I don't understand if this will be outside "under the roof" or inside run in an attic "under the roof"? I assume you are not running this "on top" of a roof...
  6. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    Pic below. I want to run wires (4 or 5 NM cables) along the blue lines, (along the roof boards, the underside of the roof deck) up to the 2nd floor ceiling.
    The area will be finished again on the interior, FWIW.
    Hopefully that makes some sense now! :D
    [​IMG]
  7. jadnashua
    I'd staple them along the side of the 2x material as close to the middle of the thing as possible. Assuming you do end up with nails IN the structure, they wouldn't hit the wire, and if you miss, unless it was right at a staple, it would probably just push the wire out of the way.
  8. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    If you run PVC conduit you can run three #12 MultiWire Branch Circuits (MWBCs) which provides 6 circuits. It requires 6 hots, 3 neutrals, and a ground, in a 1/2" PVC conduit which doesn't require the 1 1/4" distance from the edge.
    You can terminate the circuits in a large box and branch from there with indivual circuits.
    You don't have to derate #12 or #14 with up to 9 current carrying conductors in the conduit. Only the hots count as current-carrying-conductors in MWBCs.
    You can run 1/2 or 3/4" Schedule 40 PVC conduit in drilled holes in rafters or studs if you keep the holes lined up.
Similar Threads: Running circuits
Electrical Forum discussion & Blog Running a 36amp load on a 40amp breaker Sep 15, 2016
Electrical Forum discussion & Blog Running 2 Taco zone pumps off one Taco controler Mar 3, 2013
Electrical Forum discussion & Blog Running Wires in Conduit inside a wall Jan 30, 2013
Electrical Forum discussion & Blog running hot tub from alternate energy Dec 19, 2012
Electrical Forum discussion & Blog Running 3 Wire when you Only Need 2 Nov 27, 2012
