running cat6s inside plastic conduit with 120v
Discussion in 'Electrical Forum discussion & Blog' started by cmozment, Feb 19, 2011.
  1. cmozment
    cmozment New Member
    Feb 19, 2011
    Tuscaloosa, AL
    I have an underground (in concrete) 1" grey PVC line that runs about 30 feet. After it runs under the concrete and up the wall into my drop in ceiling it connects to a metal conduit box that then runs to my panel.
    The PVC line has three 12ga insulated solid copper lines (black, white and green) for power to a computer in our sales area. Is there any way to run a network line (cat 5 or prefer cat6 sheilded) in the same PVC as the 120v.
    I read somewhere that it could be done but I would need to attach the shielding from the cat 6 to the same ground as the power to keep the interference at bay. I could do this by running the wire in the PVC and then attaching the sheilding to the metal box in the ceiling.
    I want this to be safe, but it would be very expensive to tear up the concrete-marble etc to have a second run of conduit.
    Any thoughts or comments much appreciated.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I would run outdoor gel filled rodent resist and ground the rodent metal shield. I buy mine from Anixter.
    SUPERIOR C 04-003-55
    24-4P OUTSIDE PLANT CABL CAT5E
    DOUBLE JACKET FILLED CABLE
    BURIAL RODENT RESIST
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    No. It would need to have the same insulation rating as the line voltage in order to share the same raceway
  5. thassler
    thassler Member
    Dec 5, 2006
    Systems Analyst
    Tennessee
    Belden makes a Cat5e wire that is 600V AWM-rated. I've been allowed to run that in the same conduit as line voltage in the past. Never over 3ft however. Running data wire parallel with line voltage for 30ft is not a good idea even if it is shielded. In situations like that I've run fiber optic and used fiber transcievers to convert the mediums.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Only problem... I don't think the OP would fit pre-connectorized fibre through the 1" conduit. He could cut it and then rent a fusion splicer or send me return airfare and I'll bring mine.
  8. david_griffin
    david_griffin New Member
    Feb 27, 2011
    Denver, CO
    This is always a risky business to put power cables in parallel with almost not insulated cables. I would avoid it.
Similar Threads: running cat6s
Electrical Forum discussion & Blog Running a 36amp load on a 40amp breaker Sep 15, 2016
Electrical Forum discussion & Blog Running 2 Taco zone pumps off one Taco controler Mar 3, 2013
Electrical Forum discussion & Blog Running Wires in Conduit inside a wall Jan 30, 2013
Electrical Forum discussion & Blog running hot tub from alternate energy Dec 19, 2012
Electrical Forum discussion & Blog Running 3 Wire when you Only Need 2 Nov 27, 2012
