Running a Washing Machine drain under slab
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by datrik, Apr 5, 2009.
  1. datrik
    datrik New Member
    Apr 5, 2009
    Hello there,
    long time reader, first time poster.
    I'm about to do something that my gut is telling me to check with you guys and gals first. I'm moving my front loading washing machine inside my slab foundation house to a place that has no immediate drain. The closest drain is a bathtub about 8 ft. away. The main sewer line on the exterior of the house is about 16 ft. away. I was thinking about using the waterjet method to bore a hole in the dirt and meet up with one of the drains I've mentioned.
    I'd rather meet up with the main sewer line. Is 16 ft. too far for the water jet method? Is there another option that would be easier?
    Can you all give your two cents on this? Any precautions I need to know about?
    Thanks so much in advance! :D
    Daniel
  2. Terry
    Aug 17, 2004
    So you are going to wash away the dirt under your slab floor?
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I've never even heard of "the water jet method" so I guess I should just stay out of this one.
    You will need a vent and 2" standpipe with a trap.
  5. datrik
    datrik New Member
    Apr 5, 2009
    wash away dirt?
    yeah, I dont' know if this is leggit or not for interior plumbing. I've done this several times with outdoor landscaping pipe running under sidewalks/driveways. I don't plan on washing away too much dirt. Every other time I've done this in an outdoor setting, the amount of dirt displaced is not that substantial.
    kingsotall, btw, a water jet is where you plug one side of the pipe and drill a few holes in the plug and attach a hose to the other end of the pipe. The water pressure from the spigot shooting out the tiny holes cuts through the dirt and allows you to push the pipe rather easily underneath the ground.
    If you guys have never heard of this, what have you done instead?
    Thank you,
    Daniel
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Cut the concrete out so you can trench and plumb the thing right. Even if you used your water jet to bore the hole, how are you going to get the pipe in the tunnel and then how are you going to keep it from sagging and making a low spot? You can hire a professional concrete company to cut the concrete or you can rent a saw that will do it. As already noted, you must use a 2" standpipe, a P trap, a vent, and tie into a sewer line that is at least 2".
  7. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Consider whether draining into a "catch box" (I can't think of the right name) and pumping across the attic to the existing drain line might make more sense, price and disruption wise.
  8. kingsotall
    Aug 17, 2008
    Unless it's in a basement I loathe the idea of using a pump to achieve drainage.
  9. hj
    water jet
    Have you considered the fact, that if you are going to water jet a 12' distance, you need a 12' trench where you are jetting from for the jet pipe? If you intend to use short pieces glued together, there is no way you can be sure that they will make a straight pipe.
  10. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Where are you located? Florida requires 3" pipe to the 2" trap on washers.
  11. Gary Swart
    Sep 1, 2004
    Yakima WA
    Are you saying to start with a 3" standpipe then reduce it to 2" at the trap? That is contrary to the principal of never reducing a drain size.
  12. chris8796
    chris8796 New Member
    Jan 8, 2005
    Illinois
    I would cut the concrete, rather than trying to tunnel. Water jetting does not provide any control of pitch. Houses also have footings to work around. I've jetted plenty of sidewalks for irrigation, I couldn't imagine trying to go 16 ft with 2" schedule 40 under a slab house. I would be looking for a concrete cutter, preferably with a water-cooled hydraulic saw (no dust).
  13. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Not to hijack the thread but:
    It would be only reducing the drain size if you were to start with a 3" trap and then dump to a 2" standpipe.
    The local AHJ interprets as a 3" up to trap, then a 2" trap (slab on grade).
    End hijack.
  14. Gary Swart
    Sep 1, 2004
    Yakima WA
    OK, I misunderstood what you were saying. The 2" standpipe and 2" trap have to connect to a 3" or larger drain. I read it as the opposite.:D
  15. datrik
    datrik New Member
    Apr 5, 2009
    sounds good
    concrete saw it is. Thanks for all of your input. I'll have to tear up the floor, but I wanna do it right.
Similar Threads: Running Washing
Plumbing Forum, Professional & DIY Advice Leaking Dual-Valve running to Washing Machine Oct 19, 2008
Plumbing Forum, Professional & DIY Advice No hot water pressure after running washing machine Dec 5, 2007
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Wednesday at 6:13 AM
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
