Running 3/4" pex to water heater in 2X4 wall
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Didymus21, Mar 25, 2014.
  1. Didymus21
    Didymus21 New Member
    Dec 22, 2013
    Portland, Oregon
    Hi there,
    Working on replumbing the house and I've struggled to find a good game plan for running the last few lines to the water heater.
    The rigid plumbing goes through garage sole plate and takes a 90 degree up. Then, when it stubs out it takes another 90 degree. I have tees to run over and finish the washer plumbing, but the 90's in the 2X4 wall I'm having trouble with. I'm using Uponor Pex and don't know how I can get the extreme bends completed. How do I stub out with 3/4"? The bend supports I found from uponor will not fit in the 2X4 wall. If this was 1/2" I could do it no problem, but I can't find good options for 3/4"
    Thanks for any advice.
  2. DaveHo
    DaveHo Member
    Mar 12, 2010
    SE PA
    Is there some reason you don't want to use a 90 deg el? I can understand not wanting extra connections, but you're already going to have the T's. Personally, I'd run PEX to the T's & then stub out from there to the WH & WM with copper.
  4. Didymus21
    Dec 22, 2013
    Portland, Oregon
    Partly because I bought all the propex fittings online (for WH and laundry box for WM, as well as shut off valve). I can return them for a restocking fee if I have to. Also, I can't physically get a 90 deg fitting into the sole plate hole. I suppose I could try to auger it out more to get more play...
  5. Didymus21
    Dec 22, 2013
    Portland, Oregon
    I think propex discontinued their 3/4" copper stub ells
Similar Threads: Running water
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Wednesday at 6:13 AM
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Running Easy Heat Freeze Free Water Heat Pipe Cable Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Running hePex on Hot Water Tank Nov 3, 2016
Plumbing Forum, Professional & DIY Advice Water is running slow Sep 20, 2016
