Alternety
Like an engineer
I have a centrifugal pump pressurizing the house from a storage tank. Is there a way to stop the pump if the tank runs dry? Without putting a float in the tank. I am automating watering so it could possibly empty the tank if a valve stuck or a hose burst.
My thoughts were a pressure drop in the pump input or a recognizable current change in the pump.
The pressure approach, I am not sure there is enough of a recognizable change to stop the pump before damage. I have no idea just how sensitive they are to running dry. A simple pressure switch like I use for turning the pump on and off, before the pump would be fairly easy. But I have no idea if it would provide the necessary protection.
Current in the pump would need to consider changes due to output loading as pressure tanks fill.
Any suggestions appreciated.
