Run dedicated 3/4" pex to master shower?
Discussion in 'Shower & Bathtub Forum & Blog' started by ceiiinosssttuu, May 30, 2013.
  1. ceiiinosssttuu
    ceiiinosssttuu New Member
    Apr 23, 2013
    Idaho
    I ran one 3/4" hot pex line to the master bathroom which serves a manifold that branches into five 1/2" pex lines. There are 3 fixtures plus 2 shower heads on pressure balancing valves. I don't want to have a pressure drop if both shower heads are going and someone turns on the hot water in the sink, for example. Should I run a separate 3/4" pex hot line that is just dedicated to the master shower? Is that necessary?
  2. jadnashua
    The key is how much will be running at the same time. One 1/2" pex line feeding two showerheads is close to that tubing's max flow depending on the hot/cold mix. 3/4" pex is somewhat larger than 1/2" copper, and 3/4" copper is probably a good size for a bathroom group. If the pressure drops on the cold side (sink and someone flushes the toilet), that may be enough with 1/2" line to cause a pressure balance valve to throttle the hot side while it's also feeding the shower. Pex is good because it uses fewer fittings, and thus has less friction loss, but volume still depends a significant amount on ID, and copper beats it size-for-size.
  4. ceiiinosssttuu
    Apr 23, 2013
    Idaho
    Sorry I forgot to mention: I ran two 1/2" pex hots and two 1/2" pex colds to the dual shower. With 3 other fixtures in the bathroom besides these, do I have to worry about a pressure drop if someone uses the sink because the entire bathroom is fed by one 3/4" pex hot and one 3/4" pex cold? Or should I cap off the 1/2" hot lines to the shower and run a dedicated 3/4" pex line to the shower all the way from the 1" main in the mechanical room so it has all the volume to itself?
  5. Terry
    Aug 17, 2004
    You are fine with what you have done.
    You did right by running 3/4" to the manifold, and then running 1/2" to each fixture. You're golden!
Similar Threads: dedicated master
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
Shower & Bathtub Forum & Blog DIY SHOWER MASTERPIECE: Video Guide for Shower System Installation Aug 14, 2015
Shower & Bathtub Forum & Blog Master Bathroom Plumbing - Issues Jul 16, 2015
Shower & Bathtub Forum & Blog Help with Large Master Shower plumbing Mar 17, 2015
Shower & Bathtub Forum & Blog Find the leak?? Damp drywall seams below master bath. Feb 7, 2015
