Rudd 80% efficiency gas-fired furnace.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by canton, Apr 7, 2006.
  1. canton
    canton Plumber
    Jul 24, 2005
    Massachusetts
    This unit is a 100,000 Btu upflow gas furnace with a power vent, and on the vent instruction's that vent pipe may be B-1 pipe to vent outside. I'm wondering it's it alright to vent directly into the chimney with 5" smoke pipe, the furnace is 20" away from the chimney. It notes that Common venting is allowed. Follow the National Fuel Gas Code. ANSI Z223.1 and/or the Natural Gas Installation Code, CSA-B1149.1
Similar Threads: Rudd efficiency
Plumbing Forum, Professional & DIY Advice Cruddy fixture --> PITA ---> nightmare !! Oct 31, 2006
Plumbing Forum, Professional & DIY Advice In joist heating efficiency different substrates Oct 22, 2012
Plumbing Forum, Professional & DIY Advice Can I Tap Into Drain Pipe to Drain Condensate From High Efficiency Furnace Mar 6, 2010
Plumbing Forum, Professional & DIY Advice Tankless HW Heater and High Efficiency Washer Mar 26, 2009
Plumbing Forum, Professional & DIY Advice Bradford White High efficiency Jan 19, 2008
