RPZ vs check valve
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mbartosik, Mar 9, 2007.
  1. mbartosik
    mbartosik New Member
    Jan 18, 2007
    Since my well pump was unfortunately a little oversized (3/4HP when 1/2HP would have done), I am going to use it to drive irrigation also.
    The well is currently only used for ground source heat pump NOT drinking/house water.
    Should I use an RPZ valve ($180) to separate heat pump from irrigation or will a simple brass check valve be sufficient (my guess $30) ?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I don't know what an RPZ valve is, and I'm not sure I understand the question. Why would you need a valve at all?
    bob...
  4. mbartosik
    Jan 18, 2007
    Rpz
    I need to stop back flow of potentially dirty water from the irrigation system into the heat pump system. So I should use at least a check valve.
    If you connect an irrigation system to a domestic water supply a check valve is not enough. In the United Kingdom they used to require an intermediate tank. In the USA an RPZ (reduced pressure zone valve) is required. It contains I think two check valves with a center chamber (zone) that can relieve pressure in case of failure of one check valve.
    Currently there is an RPZ valve between the irrigation and domestic water supply. But my well supply would be tied into the irrigation side. I am wondering if a second RPZ to protect the geothermal system from irrigation is overkill or whether an normal check valve is enough.
    Connecting the well to the domestic side is not good because the well is not tested for potatable water.
    An example of an RPZ can be found here:
    http://www.plumbingpages.com/featurepages/OverviewGrant.cfm
  5. Rancher
    Rancher Guest
    Probably a dual check valve assembly would be enough protection, that's all that's required on residential wells to city water supplies.
    Rancher
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Here you can't connect water wells to city water in any fashion. It's frowned on heavily by the powers that be. In my opinion, the city would be contaminating the ground water not the other way around.
    bob...
  7. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Speedbump,
    its the same here in Massachusetts too.
    SAM
Similar Threads: check valve
Pumps and Tanks Well Forum & Blog. Water is life. Check valve Jan 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Stuck open check valve in the well Dec 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Simmons "lifetime warranty" check valves & Products Sep 2, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Check Valve and Pressure Switch Aug 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Replaced check valve, now no real flow. Aug 15, 2016
