Rough Plumbing-Bath to Shower Conversion HELP
Discussion in 'Shower & Bathtub Forum & Blog' started by steveg91, May 18, 2010.
  1. steveg91
    steveg91 New Member
    Aug 14, 2006
    Hi folks, wanna turn this into a shower. Will be installing a 2" ABS drain ( Schluter Drain ). How do I proceed.
    Thanks so much,
    Steve
      File size:
      42.6 KB
      1,249
      File size:
      34.3 KB
      518
      File size:
      47.6 KB
      724
      File size:
      48.1 KB
      403
  2. jadnashua
    WHere's the vent line for that tub connection? I think to answer your question, we'd need to see more of what's underneath the floor and back in the wall. Is the rest of the plumbing abs, cast iron, or continues in brass or copper?
  4. Terry
    Aug 17, 2004
    The tub waste and overflow gets thrown out, you will need to move the drain and p-trap.
    It would be nice if you can go far enough back to upsize to 2"
    Some banded shielded couplings can transition to new pipe.
    [​IMG]
  5. hj
    Given the pictures you show there, you DON'T. You need to open up the floor until you locate a 2" drain line, then route it to the new shower's drain location.
Similar Threads: Rough Plumbing-Bath
Shower & Bathtub Forum & Blog Grohflex rough in box upside down Feb 4, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Shower rough in diagram Aug 31, 2016
Shower & Bathtub Forum & Blog Above floor rough trip lever tub drain Aug 9, 2016
Shower & Bathtub Forum & Blog Low water flow to a shower head can be caused by a low-flow rough-in valve/cartridge Apr 9, 2016
