Rough Opening for Door
Discussion in 'Remodel Forum & Blog' started by nelsonba, Nov 16, 2007.
  1. nelsonba
    nelsonba Member
    Sep 28, 2005
    Minnesota
    I'm planning to use some doors for my remodel project that are not pre-hung. (They were in my storage space and match the rest of the doors in the house). What would be the proper size rough opening for the framing? I assume I need enough space for the door jambs and some room for shimming. What would be the standard door jamb thickness? How much room do I need for shimming?
    Thanks
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Typically you would add 2" in width and height, but you should have the actual frame on hand, or specs for it, to be sure.
    A typical 36 X 80 door would be roughed at 38 X 82
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Usually 3/4", and with the inch Jimbo mentioned allowed for them.
    The 1" allowance all-around should be more than enough unless the "rough framing" is a bit too "rough" and way-out-of-square.
    Use tapered shims in pairs with one coming in from each side so the net result is flat unless the lumber around your opening is twisted. Also, be sure to shim directly behind the hinges, if necessary, and to screw at least the top hinge all the way into the framing to keep the door edges plumb/parallel with the jamb.
  5. AZ Contractor
    AZ Contractor In the Trades
    Apr 21, 2007
    Phoenix, AZ
    Where do you get 1"?
  6. leejosepho
    Nov 23, 2006
    What number or numbers do you use?
  7. AZ Contractor
    Apr 21, 2007
    Phoenix, AZ
    Jimbo is correct. 36 inch door gets a 38" RO.
    35 3/4" door
    + 3/4" jamb
    + 3/4" jamb
    +3/16" gap on strike and hinge side.
    =37 5/8"
    the 38" RO gives you 3/8" of play.
    where do you get 1"?
  8. leejosepho
    Nov 23, 2006
    38" - 36" = 2" (1" all-around)
    What part are you missing?
  9. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    answer; it could be part of his brain that is missing:p
  10. leejosepho
    Nov 23, 2006
    Oh, maybe it is something as simple as "all-around" being mistaken for "overall", eh?!
    Overall, we are talking about allowing an inch all-around ... yet I did recently frame a wall and install a 4'x6' window in my new workshop with only 1/4" clearance overall!
  11. AZ Contractor
    Apr 21, 2007
    Phoenix, AZ
    When you mentioned 1" all around and rough framing way out of square in the same breath it sounded like you were talking about shim space.
  12. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    As opposed to the 3/8ths AZContractor just explained...?
  13. leejosepho
    Nov 23, 2006
    Ah, okay. I did not speak clearly while meaning to say 1" all-around the actual size of the door should leave enough room for jamb, shims and squaring, overall.
    No, openings for windows are figured differently, but yes, 3/8" could have been okay.
Similar Threads: Rough Opening
Remodel Forum & Blog Help with bathroom rough in layout Apr 24, 2016
Remodel Forum & Blog How to Install Back to Back Wall Hung Toilets on 1962 Rough-in Stack Aug 30, 2015
Remodel Forum & Blog 10" Rough In Toilet Jun 30, 2015
Remodel Forum & Blog Sealing vertical pipe penetrations through Concrete? May 20, 2015
Remodel Forum & Blog Removed galvanized service line and pull through poly? Apr 1, 2015
