Rough In
Discussion in 'Toilet Forum discussions' started by steelcable97, Mar 18, 2008.
  1. steelcable97
    steelcable97 New Member
    Mar 18, 2008
    I want to replace two toilets.
    The rough in distances are 11in for the first, and 13 1/2 for the other.
    I want to get an American Standard Cadet 3. Can I use a 12 inch rough in?
    Thanks.
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    The absolute minimum roughin to a finished wall for a cadet 3 is 11 1/4" (this will be very tight, but will fit)
    . However, a good plumber will make an 11" roughin fit. You can steal/cheat from the bowl and tank installation
  4. Johnnie_Rocket
    Johnnie_Rocket New Member
    Mar 16, 2008
    League City, Texas
    I've seen offset flanges in home stores that look like it sets the flange a little further (or closer) to the wall. Can this be a solution? I've used my new Cadet 3 a few more times and still like it but buyers should be aware of a potential for poor china build tolerance.
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Thats a possible solution, assuming you have access to the vertical part of the drain and you have enough depth/space between your new offset flange and the existing 90 degree fitting below the floor. This flange will allow you to gain up to 1 1/2"
Similar Threads: Rough
Toilet Forum discussions TOTO Ultramax II rough in distance Jan 31, 2017
Toilet Forum discussions Replacing Toto Ultimate round bowl, 14" rough in - no knee room Jan 21, 2017
Toilet Forum discussions Toto Entrada and rough size Jan 19, 2017
Toilet Forum discussions What is the rough in distance for this toilet? Jan 9, 2017
Toilet Forum discussions Best American Standard 12" Toilet for 11" Rough In Jan 2, 2017
