Rough-in Side Wall Before or After Installing Alcove Tub
Discussion in 'Shower & Bathtub Forum & Blog' started by Mathelo, Mar 26, 2014.
  1. Mathelo
    Mathelo Member
    Dec 16, 2012
    CT
    I'm remodeling our hallway bath and I've gutted it to the studs including removing the partition wall for the alcove tub.
    It seems to me it would be easier to install my new cast iron tub (400 lbs) before I install this partition wall. This is the wall that the plumbing fixtures will be installed on.
    Does this make sense or am I missing something.
    Louis
  2. Mathelo
    Mathelo Member
    Dec 16, 2012
    CT
    So I think I've answered my question. I've done a bit more research and I see the recommended approach for installing an alcove tub requires a ledger board. It would be kind of hard to install a ledger board if all three walls aren't in place so I'm pretty sure that means I need to complete the rough-in before installing the tub.:p
    Louis
  4. Mathelo
    Mathelo Member
    Dec 16, 2012
    CT
    On the other hand, I just took a look at the installation instructions from Toto for this 1525 tub and they specifically say NOT to support the tub by the rim. Now I'm confused. :(
    "WARNING: Do not support the bathtub by the rim. Provide adequate support under the bathtub feet."
    http://www.totousa.com/Portals/0/ProductDownloads/0GU5019_CAST_IRON_BATHTUB_IM_OM.pdf
    I suppose the right answer might be to do both so its really locked in but their warning does concern me.
    Louis
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    How do you adjust the legs for support and levelling? Can you reach with the walls in place? Or do you need to go back and forth? Tub in - check - out - adjust - back in check - adjust - etc.
    This might help you answer your own question.
    You might check the area first and see which side is high. If for example you plan to leave the left side open this would free up both levelling legs there. This would be easier than lifting that heavy beast back in and out for fine tuning.
    Good Luck.
  6. Mathelo
    Mathelo Member
    Dec 16, 2012
    CT
    If I install the tub as I was originally thinking I wouldn't put up the third wall until I had the tub installed. This third wall will include the plumbing fixtures. I intend to make sure the subfloor is flat and put steel plate - or something similar - where the four feet will rest. I know getting 4 points exactly flat from the get go is near impossible but I'll have fairly easy access to 3 of the legs so shimming in place shouldn't be too difficult.
    I get how the ledger board makes for a simpler and more stable install but it conflicts with the manufacturer's warning. I know some of you don't think this warning is worth the paper it is written on but I have a hard time reconciling that with the manufacturers expressed concern. They must know something about the product they manufacturer. I guess if I had a better understanding for why they have this warning, I could get more comfortable with the ledger board approach. Is it because the tub rim is not strong enough to support the weight or is it concern about how the framing and ledger board is installed?
    I've been thinking that an alternative approach is to use ledger board but put each leg in a small pan of mortar. When the mortar sets up, the weight will largely be born by the legs with the ledger board fixing it in place relative to the tile. Does this make sense or am I missing something?
    Louis
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Moving around a cast iron tub is a bitch of a job for three guys. For two it ****ing sucks.
    They weigh a lot. Once sitting down it is is not to hard to adjust the levelling legs if you can reach them.
    Sounds like you have a good handle on this.
Similar Threads: Rough-in Side
Shower & Bathtub Forum & Blog Low water flow to a shower head can be caused by a low-flow rough-in valve/cartridge Apr 9, 2016
Shower & Bathtub Forum & Blog Custom Shower Plumbing Rough-In Advice Needed Jul 8, 2015
Shower & Bathtub Forum & Blog Roman tub filler trims for Kohler K-300-K rough-in? May 21, 2015
Shower & Bathtub Forum & Blog Grohe 35015000 Universal Pressure Balance Rough-In valve Feb 10, 2015
Shower & Bathtub Forum & Blog Stud interferes with new rough-in valve placement Dec 5, 2013
