"rough in" questions
Discussion in 'Shower & Bathtub Forum & Blog' started by the pelon, Mar 3, 2008.
  1. the pelon
    the pelon New Member
    Mar 3, 2008
    Hello all, I was refered to this forum by my good friends at the John Bridge site. I am in the process of a shower remodel. here is my plan: Install a new 3/4" thermo valve on the incoming 3/4 hot and cold lines. Stub out of the thermo valve with 3/4" and then "T" into 1/2". 1 line going into a 1/2" contol valve to feed shower head on one wall and the other 1/2 line to another control valve on the opposite wall for a hand held shower head. Any issues so far??
    Now to some finer points. What are some thoughts on the Kholer Mastershower products, valves ect. I am looking for something that wont break the bank, but don't want to tear into my tile wall in a year later to repair the themo valve or control valves. Is there a better way to run 2 shower heads without using a therostatic valve and control valves or is this pretty much standard. Is there a concern with thermo valves that hot water may "syphon" off into adjoining cold water sources such as faucets, toilets ect. Well, enough for now!!!:D Thanks in advance, Pete
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    :)Just a tip here. You only need to post a question in one place on this forum. Just select the section that seems to be the most logical for you question.
  4. the pelon
    Mar 3, 2008
    sorry Gary, still learning :confused:
Similar Threads: rough questions
Shower & Bathtub Forum & Blog Shower rough in - questions about valves... Sep 4, 2009
Shower & Bathtub Forum & Blog Moen rough-in tub/shower valve questions? Dec 31, 2007
Shower & Bathtub Forum & Blog Grohflex rough in box upside down Feb 4, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Shower rough in diagram Aug 31, 2016
