Rough in move done
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by snokel, Feb 3, 2014.
  1. snokel
    snokel Member
    Jan 29, 2014
    Wi
    Just finished moving my basement rough in a couple of feet over to clear beam and hvac.
    The shower drain moved over about 2.5 feet and I had to add a dry vent because it was more than 8 feet from the
    wet vent. The string is the plumb bob I used to position the vents so they will be in the wall which will incorporate the
    the 3.5 inch rigidlam beam.
    The Water closet and lav wet vent is exactly the same except moved over to clear the beam and hvac.
    I used a combo on the wet vent because it sat just a bit lower than using a wye and 45 combo.
    Did 3 days of research and I think it will pass inspection (which is tomorrow).
    I adjusted the pitch a bit and dumped 5 gallons of water down each drain and no problems.
    comments?
  2. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    Looks like it will pass with flying colors
  4. snokel
    snokel Member
    Jan 29, 2014
    Wi
    Thanks, I hope so. Now I just have to haul the bags of concrete down for a pour this weekend :)
    The water closet rough is a bit more than 12 inches, about 13.5 that should be ok though. I kind of like the tank a bit further from the wall, makes it easy
    to paint back there :)
  5. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    did you just use the sledge to break up the concrete or did you rent a jackhammer
  6. Terry
    Aug 17, 2004
    It's nice to see a homeowner rough in that we can give two thumbs up on!
  7. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    Yeah separate vents...no flat vents. That deserves the two thumbs up.
    But where and how is the lav plumbed in? Is he hiding something???
  8. snokel
    snokel Member
    Jan 29, 2014
    Wi
    Yes, I used a 4lb and a 12lb sledgehammer and a cold chisel to bust it all up. Took about 6 hours to break up including the hauling of the chunks.
    I cheated on hauling the chunks out, I just threw it all out the egress window on the mulch bed and will haul away in the spring when the snow is gone :)
    oh, I also used a hammer drill to drill holes around the perimeter to control cracking and that mostly worked, I had to open it up more than I wanted because
    the shower drain was close to the wall and it just hairline cracked like crazy in that area so I just opened it up to the wall, not a big deal since we are in a deep
    freeze here in wisc right now and the form a drain is bone dry. will feel better when it's filled back in though :)
  9. snokel
    snokel Member
    Jan 29, 2014
    Wi
    Here is the original setup before I took out the gravel:
    I accidentally cracked the wet vent behind the WC and that's what that red tape is sealing up :)
  10. snokel
    snokel Member
    Jan 29, 2014
    Wi
    Thanks Terry, I have to say I was stressed out about this for days before actually doing it:) Doing plenty of research before hand really helps :)
  11. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Have you talked to your inspector? More often than not in WI you will be required do do a stack test or pressure test to prove the integrity of your connections.
  12. snokel
    snokel Member
    Jan 29, 2014
    Wi
    Yep, I have been talking to him.
    He came over yesterday and it all passed.
    I asked him about the testing and he said they normal don't require that for home owner installs unless it's a "lot" of pipe being put down.
Similar Threads: Rough move
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Remove a brick? Or drill holes through the brick? Oct 12, 2010
Plumbing Forum, Professional & DIY Advice Bathroom rough in move Aug 3, 2009
Plumbing Forum, Professional & DIY Advice Toilet 16" rough in help Wednesday at 7:55 PM
Plumbing Forum, Professional & DIY Advice Trap protrudes through vanity bottom Tuesday at 8:29 PM
