Rough estimate of the cost to switch from gas to electric
Discussion in 'Tankless Water Heater Forum' started by chubyball, May 31, 2009.
  1. chubyball
    chubyball New Member
    Dec 15, 2006
    I was thinking replacing my water heater to tankless is there a lot of cost for doing this?
  2. jadnashua
    It will likely be expensive. You may need to get your entire electrical system upgraded to have enough power. Energy density to use a gas version is probably a better choice but, just replacing what you have with (maybe) a larger tank may end up far more ecconomical. Depends on what you are trying to accomplish.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    1 Therm of energy can be had from approx. 100 cubic feet of natural gas or 29 kwh of elec heat.
    What are the rates in your area? I pay 16¢/kwh (=~$4.60/therm) and $1.10/therm of NG.
  5. khayes
    khayes Member
    Oct 25, 2005
    Alpharetta, GA.
    Thatguy - you have one creepy avatar! :)
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Yes, I got a bunch of photos from Germany that were taken all over the world.
    This one makes a good case for
    http://en.wikipedia.org/wiki/Endangerment
    on the part of the parents (if he/she has parents).
  7. PatPro
    PatPro Mechanical Engineer
    Jun 10, 2009
    Mechanical Engineer
    Virginia Beach, Va
    Tankless system costs
    Assuming you have an electric tank type water heater now and you want to install a gas tankless system, you are probably looking at about $2,500.00 dollar range. You will need to extend your gas piping (and make sure you have enough capacity at your meter), provide venting for combustion air and the products of combustion, toss in a little bit of pipe work and lastly a bit of electrical work for the tankless unit controls/spark. You can find out more information at http://www.mechanicalengineeronline...ater_Heaters_Ebook/Tankless_Water_Heaters.htm
    If the new unit will be electric, probably $1,500.00 if the panel is big enough to power the electric tankless system and about $2,500.00 if you need a sub-panel (service entrance needs to be verified).
    It is good that you are thinking of this before your tank type system quits.
Similar Threads: Rough estimate
Tankless Water Heater Forum Water flowing through tankless heater at beginning and end of cold water draws Nov 20, 2014
