Rotted studs
Discussion in 'Shower & Bathtub Forum & Blog' started by encinitaz, Oct 28, 2008.
  1. encinitaz
    encinitaz New Member
    Oct 27, 2008
    I am replacing a bathtub and surrounding tile walls due to water damage.
    After I tore out the walls I found the wall studs are rotted. The plumber doing the bathtub replacement said to leave them in and he will put new studs in next to them. Do I need to cut away the rotted portion of the existing studs or anything else to mitigate the rotting?
  2. jadnashua
    If it stays dry, it will stop rotting. If it gets wet again, the punky wood (like a sponge) would hold more moisture to allow it to rot faster.
  4. citm2000
    citm2000 New Member
    Oct 24, 2008
    South Carolina
    If you live where there are termites, you should remove the rotted wood. Most termite bonds won't cover any infestation that happens as a result of water damage.
  5. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    The rotted wood, even once dry, contains the spores for further rot.
    Take it all out.
  6. jadnashua
    Spores are almost literally everywhere. They don't do anything if it is dry.If they are no longer structural, you either need to replace or sister, but again depending on how bad they are, there may not be much to sister to.
  7. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    There is no time like the present ... rip it out! It's easy.
  8. frenchie
    Dec 30, 2006
    Caretaker
    Everywhere, sure - but not in the concentrations you'll find on an already-rotting piece of wood.
    I work on beach houses a lot; and I used to work on boats.
    I stand by my previous statement: if the new wood ever gets damp, it will rot out MUCH FASTER if it's up against old rotted wood, than if the old rotted wood was removed.
Similar Threads: Rotted studs
Shower & Bathtub Forum & Blog Rotted subfloor under cast iron tub, considering my options. Oct 10, 2016
Shower & Bathtub Forum & Blog Ideas on rotted window in shower Aug 12, 2008
Shower & Bathtub Forum & Blog Just installed acrylic Delta Tub and 3 piece surround (attach to studs type) Dec 11, 2016
Shower & Bathtub Forum & Blog Tub/shower valve installation with 2x3 studs Aug 13, 2013
Shower & Bathtub Forum & Blog Gap between shower pan and studs Mar 27, 2013
