Roto Rooter up Date
Well...the original Roto Rooter installer of the bad, not to code job called the woman and said he would be over in an hour to see what the problem was...when he showed up the H/O sat quietly as he inspected his work, or so she assumed as she is blind and can't see, the guy states to her that yes it needs a new / different coupling at the connection in the wall, a banded coupling...but that is all it needs...nothing more...she said are you sure...the other plumber said the pipe was level and needed to be pitched and that it needed support and that the trap was not the right one...Roto Rooter now changed their tune and said well when we change the trap it will make the correct pitch and we can add a hanger...Ill be back when it is convenient for you...
If she hadn't said anything they were going to leave it like it was with the exception of changing the transition coupling to a banded one.
They were going to try and get away with as little as possible and not make the job right...figures...we will see what happens...to be continued...
