KineticoUser
- Messages
- 187
- Reaction score
- 3
- Points
- 18
One of my showers backed up once, so I figured something is reducing the flow out of my septic tank. I removed the covers to the tank, and the level looks higher than normal. I dug up the output side of the tank and found a culprit. Here is what it looks like. https://1drv.ms/i/s!AnhFeJX0YorirQd-smyGGmPtKSQ7
I probably need to dig up the input side also, as that may have the same problem. I'm thinking of building a box around the line in and out to reduce the likelihood of roots finding it again, but I'd appreciate your feedback on what would be the best way to fix this problem. If I cut the pipe, I figure I'll have a flood on my hands, so another solution would be appreciated. I'd prefer not having to pay a few hundred dollars to drain the tank, but will do so if that is the only option. If I need to cut the pipes and reinstall them, what do you recommend to seal it into the tank, so it doesn't attract roots again? A juniper bush near one of my seepage pits looks healthier than the others, so I'll probably dig down to the top of that pit, also. If I need to redo the seal, would it be the same seal I use for the septic tank?
