Root Intrusion Advice
Discussion in 'Drain Cleaning' started by sewerman, Dec 7, 2006.
  1. sewerman
    sewerman New Member
    Dec 7, 2006
    I have root intrusion in my cast iron sewer line. The intrusion is right at the joint of the end of the cast iron line to the city ABS line and it is under the alley (outside of my property) My plumber wants to do hydro-jetting and says the city wont take responsibility.
    my questions:
    (1) Is it really my responsibility (since it is under the city's alley)?
    (2) Is hydro-jetting the best method for root removal? and can the pipe be sealed from further intrusion?
    (3) Will taking out the offending plant (likely an oleander bush directly above) solve the problem?
    thanks
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Yes, I would suspect so, as the city will likely say its line is fine and yours is the one with the problem ... and I do not know the answers to your other questions.
  4. hj
    roots
    In most cases it is your responsibility until it reaches the city main in the center of the alley.
    It is the most expensive way, snaking is usually just as efficient. There is no inexpensive way to seal the pipe. Just snake it when it stops up. When you have to snake it every 9 to 12 months, then it will be time to replace it.
    It MAY cure the problem about 25 years after you remove them, but not likely until then, and even that may not be a long enough time period. I have had customers with root problems from trees they forgot had even been there.
    thanks
  5. prashster
    prashster New Member
    Dec 7, 2005
    There is a way to permanently seal the pipe. But I'm sure it's expensive. Basically, it involves epoxy sealing the inside of the pipe using a bladder that's airshot thru the pipe. Saw it on TOH.
Similar Threads: Root Intrusion
Drain Cleaning Roots - slow drain and will back up (Slab Floor) Dec 18, 2012
Drain Cleaning Original Root Rat Chain and Cable Kits Oct 11, 2012
Drain Cleaning Is Roto Rooter Ripping Us Off? Jul 27, 2012
Drain Cleaning Tree roots too big to snake out with blade? May 10, 2012
Drain Cleaning Clogged drain (video) Tree root? Dec 6, 2011
