Room enuf under the stairs?
Discussion in 'Boiler Forum' started by, Dec 29, 2009.
  1. New Member
    May 4, 2007
    A small new house will be built over a 4-foot deep crawlspace foundation, and the mechanicals are planned to go in the space under the stairs. By doing that, we can permit a little better room for the boiler and related gear.
    Proposed unit is a small Lochinvar mod-con wall-hung, and the box shown in the attached images is about the size of one of those. The cylinder in the images is the size of a 40 gallon indirect DHW, for which the boiler will supply heat. It is also supplying heat for the ten panel radiators throughout the house, above.
    Boiler specs call for a minimum of clear space in front of it, and this configuration meets that for sure, with ease.
    There seems to be enough room on that wall, in the under-boiler area, and all that space between it and the DHW, for the near-boiler piping, manifolds, circulators, controls, and such, but what do you think?
    Our local AHJ has cleared this as re code issues, provided we cover the stair bottom and adjoining wall surfaces with type-X gyprock.
Similar Threads: Room enuf
Boiler Forum Radiant floor heating boiler room plumbing layout. Feb 4, 2016
Boiler Forum Oil on the boiler room floor Dec 1, 2015
Boiler Forum hydronic heat changes in bathroom reno Oct 23, 2013
Boiler Forum Relays for roomstat question Nov 25, 2009
Boiler Forum Where should I place a baseboard radiator in my bathroom? Nov 19, 2009
