roof vents, septic smell, studor valves
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by juicy, Dec 27, 2004.
  1. juicy
    juicy New Member
    Dec 27, 2004
    Howdy-
    our house is in a small valley, and it gets very windy. Under certain conditions, the yard smells like sewage. Homeowners in the vicinity have had similar issues, and solved them by installing a charcoal filter on the septic vents exiting through the roof.
    These filters seem to be hard to come by, at least locally. Plumber friends have suggested installing a studor valve instead, and studor valves are much easier to get. Will they be just as effective?
    I've also read that I can't just install a studor valve on every vent in the roof: at least one of the vents must be open to let outgassing occur. Is this true?
    There are 3 vents: one 2" PVC, one 2" ABS, one 3.5" ABS.
    Reading this, does anyone have comments or recommendations?
  2. jadnashua
    Studor valves only let gas (air) IN, not out. Your vents need to go OUT (well, mostly) to let the sewer gas escape.
    The vent system, if it is working properly, allows the sinks, toilets, etc. to drain properly. The traps in those devices keep sewer gas from sneaking in the house. Assuming thatyour vent system is installed properly, the sewer gas is coming in from an open window or other air vent.
    Check each sink, toilet, tub, etc. and see if you smell anything coming out of it. You probably won't. But, if you do, a faulty or blocked vent may have allowed the water thatis in the trap to siphon out.
    I'm not a pro, but it seems thatthe vent is supposed to be high enough so that the top is 2' above the roof peak. You might want to double check that value, but just like smokestacks, raising the outlet gets it into the airstream and carried away better than getting caught in the air current eddies often present on a roof.
  4. juicy
    juicy New Member
    Dec 27, 2004
    Fixed.
    Thanks for the reply.
    The instructions that came with the studor valves said that one pipe on every house must be open to the air, to allow gas to escape. So we attached studor valves to two of the roof vents, and capped the third with a charcoal filter (much more expensive than studor valves). The odor disappeared. Everything still flushes/drains. Problem solved!
  5. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    You put Studor vents on your roof? Your plumber friend told you to do this?
    Deb
    The Pipewench
Similar Threads: roof vents
Plumbing Forum, Professional & DIY Advice Raising the roof.... Eh herm, ceiling. Advice moving plumbing and vents. Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Roof vents too short? Apr 17, 2015
Plumbing Forum, Professional & DIY Advice Plumbing Vents on My Roof Jul 11, 2014
Plumbing Forum, Professional & DIY Advice Combining vents. Please proof my layout. Jun 6, 2014
Plumbing Forum, Professional & DIY Advice Reducing roof vents in roof replacement May 12, 2014
