Roof Mounted Attic Fan on a Dimmer Switch?
Discussion in 'Electrical Forum discussion & Blog' started by bjferri, Jul 19, 2009.
  1. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Department of the Army Civilian (DAC)
    Maryland
    I have an Nutone attic exhaust fan I would like to slow down a bit. Can I put a dimmer switch of some sort on it? Any ideas? They sell similar items to control ceiling fan speed - is that an option?
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    NO, not a dimmer. You need a motor speed control, but it MUST be rated for the motor it is controlling.
    Verify the amperage of the motor and go to a real electrical supply house and get what you need.
  4. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    I have also have a Humidistat and Thermostat connected. Do I need to verify amps of those items too? Where would I make the connection for the motor speed control? I'm trying to find the fan amps as I write this...
    Thanks.
  5. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Found it! 4.3 amps.
  6. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Put the speed control last in line before the motor. You do not want to vary the voltage into the two stats.
  7. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Gotcha! Thanks again!
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Putting it is series with an incand. lamp probably won't damage it. Less wattage= more speed reduction.
  9. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Can you clarify this? I really don't understand...
    Thanks...
  10. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    It's a series circuit: a 120v source in series with the lamp in series with the fan.
    If the fan draws 100w@120v and the lamp draws 100w@120v, then when you put them in series each will get half voltage and 1/4th the power, so the fan will move more slowly and the lamp will hardly glow at all.
    The trouble is an incand. lamp has a resistance that depends on the current through it, so you should try different size incand. bulbs until you find one that gives you a satisfactory fan speed.
    With 7-1/2w the lamp will probably glow full brightness and the fan won't move and with 100w the opposite will be true, depending on the fan size.
  11. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    I think I understand, but does this mean I will always have a light burning in the attic?
  12. jadnashua
    Yes, until the bulb burns out, and then the fan stops. Depending on the motor controller, some act like that and generate a fair amount of heat. Some chop the output.
    You might want to check the motor itself...some have multiple windings, allowing more than one speed. They save money by not wiring them up. All you may need is a 2-3 position switch, properly wired to control speed. If there are more than two wires to the fan motor, look closely at the data plate. You might be lucky. Also, there may be a set of jumpers...those may allow an alternate speed.
  13. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    I'm not exactly sure what to look for but am I safe to buy a Motor Rated Fan Speed Control to replace the existing on/off switch? So long as the amps are okay?
    I was also told I may be able to rewind the motor but if it's easier replacing a shutoff switch I'd rather do that. Or but a smaller motor and replace... This is not my forte...
    Thanks again...
  14. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    For the cost of rewinding the motor you could buy three fans that run at different speeds.
    Is this a whole house attic fan? The kind that sound like an air plane on the runway? On the fan motor is a Horse Power rating. Find it and post it and you'll get some better advice.
  15. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    It's not measured by HP - it's an attic roof fan measured as CFM. I think my only option is to replace motor and blade assembly. I was told I could replace the on/off switch with a motor rated speed control switch but I'm not sure what it'll do to the humidistat/thermostat.
  16. jadnashua
    This is probably how those sensors work...they act like a switch. When they sense the proper conditions, they either close or open the switch. So, if that is the case, it's not much different than adding an on/off switch. The motor controller would either have power applied, or not as determined by the switches in series before it.
    the motor probably has a data plate on it...if you post that, someone may be able to tell you what your options are.
  17. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    All motors have a rating. Are you moving air out of your attic only or out of your house?
    The motor rated speed control won't hurt your stats if you put it last in line in the circut but it has to be the right kind of control- not a dimmer, not a ceiling fan control, not a 100W bulb- one able to handle the size motor you have.
  18. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    4.3A leaves out the use of a 100w lamp unless you want very slow speed.:(
  19. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    I just saw this. Do what Speedy says and you are all set.
Similar Threads: Roof Mounted
Electrical Forum discussion & Blog tamper proof receptacles Mar 20, 2012
Electrical Forum discussion & Blog Running circuits along roof? Jun 26, 2008
Electrical Forum discussion & Blog weather proof electrical box Jun 18, 2007
Electrical Forum discussion & Blog Surface mounted armored cable, or EMT? Sep 21, 2016
Electrical Forum discussion & Blog Advice on feeding house panel from pole mounted meter 200a Aug 28, 2016
