Roman Tub Faucet rough-in kit connection to water supply
Discussion in 'Shower & Bathtub Forum & Blog' started by JasonT, Aug 30, 2012.
  1. JasonT
    JasonT New Member
    Aug 30, 2012
    Mississauga, ON
    Hi all,
    I'm currently trying to install a tub with a roman faucet. The faucet's rough-in kit has already been installed onto the tub deck of the tub and the hot and cold has been soldered. I've also roughed in the main supply lines.
    When I install the tub, I'm going to have limited space to allow me to solder the copper connection between the main supply lines to the hot/cold of the faucets.
    I watched one episode of holmes on homes and I swear I saw the plumber use a braided hose to connect the supply to the roman tub faucet.
    The question I have is can I do that? I spoke to a plumber at Homedepot and they said copper is still the best. I will have access to that area in the future so I can always replace the braided hose every 10 yrs or so.
    I went to Homedepot and all they had were hoses used for normal sink faucets. Understanding that sink faucets have a lower flow rate than roman tubs, do you know if I can just use those standard braided sink faucet hoses to connect to the roman tub faucets? Would this limit the flow that my faucet will get? Basically I'll have 1/2 inch copper to a 1/2 to 3/8 shutoff valve. Then use the standard 3/8 braided hose to the roman tub rough-in kit. I'll have to solder a threaded fitting onto the roughin kit copper line to allow the hose to connect to it.
    Thanks in advance!
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Would that not take forever to fill the tub?
    JW
  4. hj
    Use 3/4" mip x 1/2" solder adapters and use 3/4" water heater connection hoses.
Similar Threads: Roman Faucet
Shower & Bathtub Forum & Blog Need help in identifying Roman tub faucet from late 1980s Oct 5, 2016
Shower & Bathtub Forum & Blog Wall mount Roman tub faucet Apr 23, 2016
Shower & Bathtub Forum & Blog Need help identifying 1980s Roman tub faucet Oct 18, 2015
Shower & Bathtub Forum & Blog Can anyone identify this Grohe roman faucet and spout? It was installed in 1990. Apr 30, 2015
Shower & Bathtub Forum & Blog What brand Roman Tub faucet? Apr 20, 2015
