I wanted to install an "S" shaped extension to get my shower head up higher ... but when I removed the current shower extension arm (Rohl 90 degree w/an integrated flange), I realized it had fe threads and there was a threaded pipe sticking out from the wall (like a tub outlet would have). Obviously, the extension I purchased will not work unless I remove the stub.
Before trying to unthread it with a pipe wrench and ruining the threads, I wondered if there was any way to make a reasonable guess that it is threaded on both ends instead of sweated inside the wall? It appears to be brass (not galvanized).
Alternatively, has anyone seen an "S" shaped extension with fe thread option, which would eliminate the need to mess around with it?
Thanks for the input!
