Rocking Toilet
Discussion in 'Toilet Forum discussions' started by Alice 456, Sep 24, 2013.
  1. Alice 456
    Alice 456 New Member
    Sep 24, 2013
    Virginia
    Hi, I'm working with an individual who has a disability. As a result he tends to drop/fall onto the toilet and over time this has caused it to rock. Does anyone have any ideas as to how to reinforce the toilet so it won't rock over time...thanks
  2. Terry
    Aug 17, 2004
    Normally you would install it with shims if needed. Then you would caulk the bowl to the floor, leaving a little out at the back in case the wax seal developed a leak.
    Then you would pick up some grab bars and install them either on the walls, or as a stand for the toilet.
  4. jadnashua
    If the toilet rocks, it's likely one of three things:
    1. It never sat flat and needed shims
    2. The floor is rotting, and not stable
    3. The flange is broken (well, the toilet could be broken, too, but that's much more obvious)
    In any case, it needs to be pulled to evaluate what the issue is, and if you're lucky, just reset with new wax ring (and probably some shims). If not, it may be time for a plumber to fix the flange, or a contractor to fix the floor.
    As to safety bars, they are a good idea. Look at some of those from www.wingits.com. You'll have a higher probability of being able to anchor them to the wall solidly without tearing them up. For whatever reason, it seems most safety bars are not made in a length to anchor to two adjacent or multiple standard wall studs! So, at least one end would just be going through the wall covering. Well, the advantage of the WingIts fasteners is that they are ADA qualified anchors even when you only have the wall, and can't go into the stud. I've used them, and they are VERY secure when installed properly.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Loosing weight and stopping drinking helped me.
    But I do miss driving the porcelain bus.
  6. hj
    If the floor is "flat and level" the toilet will NOT rock. Rocking means there are "high" points around its perimeter and you will have to shim the low points so they support the toilet at all points.
  7. jadnashua
    Well, if you have a quality toilet, this is true, but some come from the factory such that they will rock on a perfectly flat floor!
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is one reason to buy your toilet from Terry Love.
    He only sells quality products.
    I can buy a rocking chair at walmart or a big box store.
Similar Threads: Rocking Toilet
Toilet Forum discussions New toilet and the tank is still rocking Jun 24, 2012
Toilet Forum discussions New toilets rocking! 3" plastic pipe? Nov 29, 2008
Toilet Forum discussions Rocking toilet Apr 5, 2008
Toilet Forum discussions Rocking Toilet Aug 22, 2007
Toilet Forum discussions Rocking Toto toilet May 9, 2007
