Rocking toilet
Discussion in 'Toilet Forum discussions' started by jumpyg, Apr 5, 2008.
  1. jumpyg
    jumpyg New Member
    Jan 11, 2005
    Michigan
    Hi, I had a toilet that would rock forward sometimes when I sat down on it. I loosened up the nuts and shimmed it in two spots in the back. Then I tightened up the nuts and all is well.
    I'm a little paranoid that the rocking may have compromised the wax seal. I don't have any leaking or anything, but that concerns me. Should I have pulled the toilet and put in a new ring before shimming it? Thanks, I'm just looking for some peace of mind.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You're on the right track. When a toilet rocks, the wax ring seal can break. I'd pull the toilet, clean the old wax ring off of it and the flange, then set the toilet in place without a ring. If it still rocks, then determine where to shim, and reset the toilet on a new ring.
  4. jadnashua
    Yep, wax isn't like rubber...it doesn't rebound, so the movement probably caused a seal leak. Now, unless you have a backup, it may not leak liquids, but it would allow gasses to escape.
  5. Terry
    Aug 17, 2004
    JumpG, If the Cadet 3 bowl that you installed rocks, then you need to shim near the back.
    I like to set the bowl without wax first, then I can see how much shimming it will need.
    I then pull the bowl back up, put the wax down, and reset the bowl.
    When the bowl is finished being set, I caulk with PolySeamSeal around the base, except at the back. If the wax is leaking, I want to know right away.
    For peace of mind, I would just reset it.
    [​IMG]
    [​IMG]
    [​IMG]
  6. jumpyg
    jumpyg New Member
    Jan 11, 2005
    Michigan
    Thanks, Terry, I will reset it just to be sure.
    This isn't the Cadet, by the way. I did shim that one when I installed it and it's great. The rocker was a cheapie Kohler Devonshire that was here when I bought the house. I will probably end up replacing it in the future.
Similar Threads: Rocking toilet
Toilet Forum discussions Rocking Toilet Feb 7, 2015
Toilet Forum discussions Rocking Toilet Sep 24, 2013
Toilet Forum discussions New toilet and the tank is still rocking Jun 24, 2012
Toilet Forum discussions New toilets rocking! 3" plastic pipe? Nov 29, 2008
Toilet Forum discussions Rocking Toilet Aug 22, 2007
