Riser Freeze Protection
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kenbect, Feb 4, 2007.
  1. kenbect
    kenbect New Member
    Feb 4, 2007
    I have freeze proof yard hydrants in an RV Park application. Of course they are only freeze proof when they are turned off and the water drains out of the riser. During freezing weather I can keep the above-ground portion from freezing when an RV is hooked up to it by using heat tape and insulation. All heat tape I have seen is not for use under ground. How can I protect the portion of the riser that is below ground from freezing when there is frost in the ground and I have long term guests that need to stay hooked up to the water? They also use heat tape and insulation on their hoses so the only vulnerable spot is the underground portion of the riser. I am getting ready to add a new section of sites. Is there anything I can do to insulate the new hydrants when I install them?
  2. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    I'm sitting down south so I'm not familiar with having to worry about freezing for long periods of time. However, one thing I do "because it's kewl" is to put faucets in a bucket in the ground then use a stepping stone for a cover. Of course, in a nice upscale area you might want to use something with a bit more "designer" appearance that provides the same function of being out of the way as well as being protected from freezing. Underground in a hole you can use the heat tape if there is no concern with flooding and you have it on a gfi circuit....merely my suggestion.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If the supply line is below frost level, you can put a stop n waste valve at the end of the supply line then a street el to the riser. Turn the stop m waste off to drain to the supply line. If the supply line is not below frost level, as far as I know, you're screwed.
  5. harleysilo
    harleysilo New Member
    May 26, 2006
    Georgia
    The idea to make the hydrant in an enclosed area seems logical. If you didn't like the bucket idea, using that pricipal you could use the round cardboard tubes used to pour concrete footings. You could dig an hole a few inches larger than the tube you use around the hydrant, pour a "floor" first, then come back insert tube and pour around it instead of in it. If it's below flood line so to speak there is an additive you can buy to mix with the concret to make it waterproof, i used it for an above ground fish pond, it works. And then you could do whatever you need to do to make a lid for it.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    I have installed automatic horse watering systems from Nelson. They use a combination of 6" SDR pipe with insulation 4.5' deep and the benifit of trapped ground heat to prevent the piping from freezing. Then above the pipe is a small heater in the water the horse drinks from. I would bet you could use the insulation and 6" SDR and figure out the rest. Do a word search for Nelson Horse waterers and you should be able to get the info direct from them.
  7. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I had been wondering whether something like that might work, but my thought of possibly using small rocks for insulation inside a large pipe did not sound sufficient.
    Since the center of the earth is quite hot, the deeper the better, eh?! I have heard caves are consistently around 52 degrees f.
Similar Threads: Riser Freeze
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Proper material for outdoor risers and manifold Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Ok to cut my CI closet bend riser above the closet bend hub? Sep 10, 2016
Plumbing Forum, Professional & DIY Advice The PEX toilet riser was cut Apr 17, 2016
Plumbing Forum, Professional & DIY Advice Septic Riser. Apr 12, 2016
