Rinnai Bath Fill Mode with Shower Mixing Valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Chins, Mar 23, 2014.
  1. Chins
    Chins New Member
    Mar 10, 2014
    California
    Hi All,
    I am looking at purchasing a tankless hot water heater and the Rinnai I am thinking of has a remote with a bath fill feature. Basically, you tell it how many gallons of hot water you want and the temperature you would like it and it will fill the bath with the specified volume of hot water at the specified temperature and then turn off. So in theory you can walk away while the tub fills up.
    Easy enough if I had a separate faucet for hot and cold water. However, I have a shower mixing valve so I was wondering if I adjust the mixing valve to maximize the hot water and then turn the mixing valve to full hot will I get the same result? I figure that the water volume and temperature would work but would when the water heater stops the flow of the hot water would the water stop at the mixing valve to or would I just get cold water coming out?
  2. Terry
    Aug 17, 2004
    That depends on the settings on your valve. With a temperature stop, at the high setting it may be a hot/cold mix.
  4. Chins
    Chins New Member
    Mar 10, 2014
    California
    Thanks Terry. So if the valve didn't have temperature stop then it would work? Is there such a valve?
  5. hj
    The majority of "shower" valves have a pressure balancing module inside them. IF the heater turns the hot water flow off, i.e., zero pressure, the module will also turn the cold to zero pressure, effectively turning it off also.
  6. Chins
    Chins New Member
    Mar 10, 2014
    California
    Thanks, I guess I will give it a try after the install and see what happens.
Similar Threads: Rinnai Bath
Plumbing Forum, Professional & DIY Advice Rinnai R75LSi - Hot water problems for over a year! Nov 11, 2014
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Saturday at 5:58 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Feb 19, 2017
