Ridgid K-750 Thoughts Please
Discussion in 'Drain Cleaning' started by ResPlumber, Sep 27, 2011.
  1. ResPlumber
    ResPlumber Plumber
    Mar 15, 2011
    Michigan
    Looking to get a new sewer machine and was thinking about the ridged k-750. I would only be doing residential building drains and sewers mostly 4" and in some
    cases 6". I would like to keep it around 1800 bucks and this one caught my eye and have had good luck with ridgid products. All feedback is welcome as well as other options for a machine.
    Thanks For the help
  2. ResPlumber
    ResPlumber Plumber
    Mar 15, 2011
    Michigan
    I am also looking into a General Speed rooter with 5/8 cable and a general metro rooter with 5/8 cable.
  4. hj
    The disadvantage of the K-750 is that it is a "single size drum" machine. I use a small drum with a 1/2" cable for 1 1/2" and 2" drains, and a 3/4" one for the larger drains. In addition, sometimes conditions call for the machine to be separated for access to the drain, and that is either difficult or impossible with the K-750. It is also expensive.
  5. ResPlumber
    ResPlumber Plumber
    Mar 15, 2011
    Michigan
    Thanks for the info HJ. Do you have any recommendations on a machine?
    Thanks
  6. AssTyme
    AssTyme Plumber
    May 27, 2010
    Wisconsin
    It's hard to beat the Spartan lineup of drum machines.
  7. hj
    My recommendation would be based on my experiences over the past 60 years, but 'younger' plumbers might want machines that do most of the work for them.
  8. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    My father and grandfather has been using Spartan machines for well over 60 years. They are a well built machine. The K-750 is not a bad machine either. It does not have an inner drum like Spartan which cab cause some trouble if you are not careful. It is much narrower than most mainline machines so it is pretty easy to get into most tight spaces. As for price, it is not as expansive as a Spartan, or the Ridgid K-7500 or any other large drain cleaning machines. Brand new you can get one for around 1100 bucks, you can find them used for half that all day.
Similar Threads: Ridgid K-750
Drain Cleaning Ridgid K-750 Or General Speed Rooter 92 Sep 30, 2011
Drain Cleaning Ridgid k-375 May 13, 2015
Drain Cleaning Ridgid 3800 Aug 29, 2011
Drain Cleaning Is this worth the effort? Ridgid K-30 Auto-Clean Sink Machine Mar 17, 2011
Drain Cleaning Who is using the Ridgid micro sea snake ? Sep 16, 2007
