Ridgid 535 pipe threader
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bioman, Apr 29, 2011.
  1. Bioman
    Bioman New Member
    Apr 29, 2011
    Texas
    First time using a Rigid 535 pipe threader and I'm getting weird results. I must be doing something wrong, It came with 1" - 2" cutters installed; I'm doing 3/4" black pipe so I swapped those out for the right cutters. No manual with the unit, but I believe I got them installed right. When the cutting is done and the pipe is flush with the end of the die I pop the die open and there is a ridge of thick shavings clinging to the rear 2/3 rds of the threads, when I brush these away a raised spine is left. Also the threads don't seem as deep as those on the pre-threaded pipe I have. I have the lever set to 3/4" for pipe diameter.
    Anyone have any ideas?
    [​IMG]
  2. jimbo
    jimbo Plumber
    San Diego, CA
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    And if what Jimbo mentioned is all okay then there is the matter of slightly adjusting the dies...
    The properly marked place is approximate with the proper setting where the threads you made becoming hand tight in a fitting with about 3 turns.
Similar Threads: Ridgid pipe
Plumbing Forum, Professional & DIY Advice replacing drain pipe with RIDGID Model 246 Soil Pipe Cutter Aug 13, 2008
Plumbing Forum, Professional & DIY Advice Verticle Sweating, Ridgid Copper Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Ridgid drain cleaning question Dec 9, 2014
Plumbing Forum, Professional & DIY Advice Any use SDT dies in a Ridgid machine? Mar 10, 2014
Plumbing Forum, Professional & DIY Advice Ridgid Tri Bender or Single Bender Oct 14, 2011
