Rheem Performance 30 gal. Short 6 Year 4500/4500-Watt Elements Electric Water Heater
Discussion in 'Water Heater Forum, Tanks' started by wynown, Jun 13, 2014.
  1. wynown
    wynown New Member
    Jun 13, 2014
    New York
    Hi, Installed and wired hot water heat when I flipped the breaker it blew, After disconnecting the wires from the heater I flipped the breaker on and it worked fine and the wires tested fine, I'm using a basic double poll 30 amp square D breaker I bought from home depot, Is there a certain type of breaker I should be using. Thanks
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    It seems likely that you either have a short to ground , or you have a wire to wire short circuit in the water heater. I would turn off the power and troubleshoot with an ohmmeter.
    With the wires disconnected from the heater, I would measure the resistance of either heater wire to a metal pipe on the water heater or another good ground that is not part of the electrical system. Each should be something over 1 megOhm normally, and it would be something less than 10 Ohms to blow the breaker. The same applies to the terminals on the water heater.
    A wire to-wire-short would be a bit harder to detect. I would expect the resistance between the disconnected hot wires of the water heater to be more than 40 ohms for each isolated element, and more than 20 ohms if there are two elements.
    Assuming you track the problem to the water heater, with ohmmeter readings in hand, I would try phoning the manufacturer or seller.
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    It's simple he dry fired the upper element by not totally filling with water first, hince a direct short
  5. hj
    Are you sure you did not wire nut the "hot wires" together instead of to the heater's wires?
  6. hj
    Dry firing will damage the upper element but seldom to the point where it trips the breaker.
  7. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    I hate it when we never find out what the problem was.
  8. Terry
    Aug 17, 2004
    Yes, It was the circuit breaker, It wasn't resetting . Thanks again
    WynOwn
  9. Mikey
    Nov 8, 2005
    Consumer
    An inexpensive multimeter (under $10, often free with any purchase at one tool chain) is a good investment for the home troubleshooter.
  10. hj
    quote; An inexpensive multimeter (under $10, often free with any purchase at one tool chain) is a good investment for the home troubleshooter.
    And a good way to get electrocuted if you do NOT know how to use it, regardless of what it cost.
  11. Mikey
    Nov 8, 2005
    Consumer
    True; modern-day natural selection...
Similar Threads: Rheem Performance
Water Heater Forum, Tanks Rheem 80 Gallon Hybrid - not going over 125 Mar 3, 2017
Water Heater Forum, Tanks Can't light Rheem 22V40FN Nov 29, 2016
Water Heater Forum, Tanks A.O. Smith, Intellivent, White Rogers, Rheem.... error code 6 Oct 17, 2016
Water Heater Forum, Tanks Rheem PRO+G29-60N RH70 (aka XR90) - UPS? Aug 14, 2016
Water Heater Forum, Tanks Rheem tankless gas water heater always starts on HIGH! Jan 19, 2016
