Robert Carter
I picked up one of these for cheap and I found out why when I installed it. when I turned it on the red lights would barely come on and the water would be barely warm, but when you pushed the the temp button, the red lights would become bright and the water would get very hot at the tap and as long as you pushed the temp button the water would stay hot, but if you let go, the water would stop being hot. I determined that the temp thingy is bad, can that be replaced by itself or do I have to replace the whole board? I thank you guys in advance for any advice you might give me. thanks Robert Carter.
