Rheem condensing unit venting
Discussion in 'Tankless Water Heater Forum' started by Tankless in Seattle, May 5, 2011.
  1. Tankless in Seattle
    Tankless in Seattle New Member
    May 5, 2011
    Seattle
    Two questions related to the RTGH-95DVN indoor condensing unit. I am planning to use the flat horizontal termination kit that routes the intake and exhaust vents in parallel:
    1) Why do the diagrams show a condensate drain on the intake vent? If either, I would expect it to be on the exhaust vent.
    2) For a horizontal vent, Rheem specifies a slope running down to the outside. For a vertical vent, Rheem specifies the horizontal leg of the vent to slope down toward the unit. I don't understand this difference.
    I have the vent kit mounted to bevel siding, which slopes down toward the unit, presumably the wrong way. I can adjust the angle, for example, with a sixteenth bend, but first I would like to understand the principle of vent drainage, both in terms of the slope and drainage.
    Thanks in advance.
Similar Threads: Rheem condensing
Tankless Water Heater Forum Proper Venting of Rheem Condensing tankless water heater Mar 27, 2012
Tankless Water Heater Forum Rheem condensing water heater with PVC concentric vent termination kit? Mar 25, 2012
Tankless Water Heater Forum Rheem water heater need trouble shooting. Jan 14, 2017
Tankless Water Heater Forum Rheem problem with water flow switch Oct 11, 2016
Tankless Water Heater Forum Venting (Rheem) question Dec 27, 2015
