rewiring electric heater
Discussion in 'Electrical Forum discussion & Blog' started by handysoul, Nov 10, 2008.
  1. handysoul
    handysoul New Member
    Oct 23, 2006
    Hello,
    I have a small electric heater which is quite old but works great. However, the plug area from the wall for about 8 inches is now very hot. I want to replace the cord and have dismantled the unit, it looks pretty straight forward. What do you think is causing this heat in the cord to occur?
    Thanks
  2. PEW
    PEW DIY Senior Member
    From use, the strands of the wire are most likely breaking where they attach to the plug, so less wire is trying to carry the current and over heating.
    If the cord is in good condition, it would be easy to cut a few inches back from the plug and attach a new plug. Just be sure to use one for the proper current, not a lamp plug.
  4. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    An old outlet can also cause this problem. Basically a poor connection causes heat.
  5. jimbo
    jimbo Plumber
    Get some cord of the proper rating, and a heavy duty plug...not one of the little lightweight gizmos. Also, consider the possibility that loose contacts on the recepetacle are contributing to this. Replace the receptacle with a contractor grade one.
  6. Billy_Bob
    Apr 2, 2008
    Here is the best type of plug to get. These have screw down connections (instead of wrapping the wire around the screw).
    [​IMG]
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Yes, and shortens the life of motors.
    If the plug pulls out easily you should replace the receptacle.
    It's high contact impedance. There aren't many Internet links that deal with this subject.
Similar Threads: rewiring electric
Electrical Forum discussion & Blog Rewiring a 200 Amp electrical panel Oct 13, 2009
Electrical Forum discussion & Blog Rewiring a stacked washer/Dryer Jan 24, 2012
Electrical Forum discussion & Blog Rewiring Nov 2, 2009
Electrical Forum discussion & Blog Upgrade to 120 amp service without rewiring? Aug 5, 2008
Electrical Forum discussion & Blog Rewiring a house Aug 1, 2008
